    Jul 2013
    Sofia
    Hello, I recently bought a new TV, LG 47 inch. Is a mid-class TV so I experience some issues with Football (Soccer) games.
    I am a football fan, so I need to fix this. Using my satellite TV all is quite nice. But when I download a certain video file containing football match I have problems with bluring , judder etc. My TV handles well video files recorded at 30 and more FPS. I have files that are 50p (50FPS) and 59.997 FPS and the quality is really nice. But most games are 25fps and I have serious issues. So is there any way, using video converter maybe to change 25 fps to 50 or 59.997, just for the TV to handle it well? I tried a few programs but the scenes are speed up, like I am changing the video speed not FPS. Any help will be much appreciated.
    p.s Mostly I will use .TS and .MKV files. Thanks in advance.
    p.s2 Sorry for my not so good English
    p.s3 I am using the tv True Motion feature but it make it worse whit serious ghosting. Without True Motion I have blurring.
  2. It sounds like your video is 25 fps interlaced (often called 25i or 50i). And the TV isn't handling the interlace properly. Post MediaInfo reports on the video file. Even better, post a short sample of the source.
    Jul 2013
    Sofia
    Here is the MediaInfo
    General
    Unique ID : 217882621460499445169702027845640216285 (0xA3EAAA9FF4C362698054470B99F55EDD)
    Complete name : D:\Downloads\fairplay-uefa.cl.2013.05.01.barcelona.vs.bayern.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 3.40 GiB
    Duration : 1h 43mn
    Overall bit rate : 4 717 Kbps
    Movie name : 20130501 2040 - Sky Sports 1 HD - barcelona-bayern
    Encoded date : UTC 2013-05-01 23:45:01
    Writing application : mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 12:38:35
    Writing library : libebml v1.3.0 + libmatroska v1.4.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 43mn
    Bit rate : 4 239 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.184
    Stream size : 3.05 GiB (90%)
    Writing library : x264 core 130 r2273 b3065e6
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 1h 43mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 283 MiB (8%)
    Language : English
    Default : Yes
    Forced : No
    Here is a sample of the video - https://dl.dropboxusercontent.com/s/sib4fv8rnggqwc3/Video%20test.mkv?token_hash=AAGc-E...pVi5NB9Nw&dl=1
    And another link if first fails - https://www.dropbox.com/s/sib4fv8rnggqwc3/Video%20test.mkv
    Intel Core i5-2500k 4.6Ghz + Cooler Master Hyper 212+ Dual Fan | Gigabyte Z68MA-D2H-B3| Galaxy GTX 470 GC 775/1550/1738 | Corsair XMS 2x2GB DDR3 1600
  4. The video isn't interlaced. It looks to me like someone started with a 1080i25 video and deinterlaced it to 25p. If your TV's motion interpolation isn't working well with it there's not much you can do. There is software that can perform the same sort of motion interpolation but it may not do any better than your TV. Attached is a sample of the first half of your video motion interpolated to 50p using MvTools in AviSynth. And an example of the type of artifacts you'll see:
    Jul 2013
    Sofia
    I see, well, I wil wait for some firmware update and download 59.997 football games. Anyway the playback is better with the file you provided. How to use Avisynth and try 59 FPS? Thanks again.
  6. This site has most of what you need to know:
    http://www.overclock.net/t/862978/guide-double-video-framerate-for-awsome-looking-anime
    Instead of playing the script in a media player you encode it with an encoder.
    Jul 2013
    Sofia
    Sorry I need a little more info. I couldn't do it. I have some errors with this scripts and dont know what encoder to use. THanks
