  1. I'm trying to encode something using x264, but it encounters this error:
    avs [info]: 1920x1080p 0:0 @ 31065/1001 fps (cfr)
    avs [info]: color matrix: undef
    audio [info]: opened qtaac encoder (AAC-LC VBR: 63, quality: medium, samplerate: 44100hz, 2112 priming samples)
    x264 [warning]: DPB size (9 frames, 73440 mbs) > level limit (4 frames, 32768 mbs)
    x264 [warning]: MB rate (253237) > level limit (245760)
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
    x264 [info]: profile High 10, level 4.1, 4:2:0 10-bit
    x264 [info]: cabac=1 ref=9 deblock=1:-2:-2 analyse=0x3:0x133 me=umh subme=10 psy=1 fade_compensate=0.00 psy_rd=0.60:0.00 mixed_ref=1 me_range=24 chroma_me=1 trellis=2 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=0 interlaced=0 bluray_compat=0 constrained_intra=0 fgo=0 bframes=8 b_pyramid=2 b_adapt=2 b_bias=0 direct=3 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc=crf mbtree=0 crf=18.0000 qcomp=0.60 qpmin=10:10:10 qpmax=38:38:38 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=2:0.60 aq-sensitivity=10.00 aq-factor=1.00:1.00:1.00 aq2=0 aq3=0
    x264 [info]: started at Mon Jul 15 12:05:45 2013
    avs [error]: FFVideoSource: Insanity detected: decoder returned an empty frame occurred while reading frame 11
    [0.1%] 1/1226 frames, 2.703 fps, 317.29 kb/s, 1.25 KB, eta 0:07:33, est.size 1.49 MB
    [0.2%] 3/1226 frames, 3.636 fps, 1746.8 kb/s, 20.61 KB, eta 0:05:36, est.size 8.23 MB
    [0.7%] 8/1226 frames, 6.051 fps, 2797.7 kb/s, 88.04 KB, eta 0:03:21, est.size 13.18 MB
    x264 [info]: frame I:1 Avg QP:23.00 size: 421
    x264 [info]: frame P:4 Avg QP:19.40 size: 15425
    x264 [info]: frame B:6 Avg QP:21.28 size: 15644
    x264 [info]: consecutive B-frames: 27.3% 0.0% 0.0% 72.7% 0.0% 0.0% 0.0% 0.0% 0.0%
    x264 [info]: mb I I16..4: 100.0% 0.0% 0.0%
    x264 [info]: mb P I16..4: 30.0% 8.0% 5.1% P16..4: 5.7% 1.1% 0.4% 0.0% 0.0% skip:49.6%
    x264 [info]: mb B I16..4: 17.8% 6.4% 1.6% B16..8: 27.6% 1.8% 0.3% direct: 7.6% skip:36.9% L0:48.8% L1:48.0% BI: 3.2%
    x264 [info]: 8x8 transform intra:16.5% inter:81.2%
    x264 [info]: direct mvs spatial:33.3% temporal:66.7%
    x264 [info]: coded y,uvDC,uvAC intra: 12.1% 13.4% 9.3% inter: 7.0% 7.9% 2.7%
    x264 [info]: i16 v,h,dc,p: 86% 10% 4% 0%
    x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 23% 41% 7% 0% 1% 1% 1% 3%
    x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 47% 35% 11% 1% 1% 1% 1% 1% 1%
    x264 [info]: i8c dc,h,v,p: 83% 8% 8% 1%
    x264 [info]: Weighted P-Frames: Y:50.0% UV:25.0%
    x264 [info]: ref P L0: 81.4% 15.3% 2.7% 0.6%
    x264 [info]: ref B L0: 92.5% 5.7% 1.7% 0.2%
    x264 [info]: ref B L1: 92.7% 7.3%
    x264 [info]: kb/s:3520.61
    encoded 11 frames, 7.801 fps, 3539.95 kb/s, 153.17 KB
    x264 [info]: ended at Mon Jul 15 12:05:46 2013
    x264 [info]: encoding duration 0:00:01
    I'm pretty sure it's an issue with the ffmpegsource avs plugin.
  2. DECEASED
    Jun 2009
    Heaven
    But of course And you didn't post the overdue MediaInfo report about the source file
    If FFMS2 really can't deal with the source video, you'll have to choose a different input plugin.
  3. Sorry, I forgot about that, here it is:
    General
    Unique ID : 31699297728581130914826311268472458287 (0x17D9100B377489E6E935D223947C0C2F)
    Complete name : D:\pv2.mkv
    Format : Matroska
    Format version : Version 2
    File size : 15.2 MiB
    Duration : 39s 498ms
    Overall bit rate : 3 222 Kbps
    Writing application : Lavf54.21.3
    Writing library : Lavf54.21.3
    Video
    Format : VP8
    Codec ID : V_VP8
    Duration : 39s 506ms
    Bit rate : 2 966 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.048
    Stream size : 14.0 MiB (92%)
    Default : Yes
    Forced : No
    Audio
    Format : Vorbis
    Format settings, Floor : 1
    Codec ID : A_VORBIS
    Bit rate mode : Variable
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Delay relative to video : -25ms
    Stream size : 926 KiB (6%)
    Default : Yes
    Forced : No
    Writing application : Google
