Hello...
I am wondering if the LG BP330 Blu Ray player plays SACDs (not just the cd layer, but all of it).
Also, if 24/96 FLAC files are burned onto a dvd, will the player read them and play them at that higher resolution, provided that the receiver is up to the task?
Sounds likie a question from a dreammmmmmmer.
*** Now that you have read me, do some other things. *** -
Not likely unless it was made a few years ago. The only currently produced BluRay players that I know of that still support SACD (and DVD Audio too) are the Oppo models.
I just took a look and SACD is not listed as a format that player supports. Google is your friend you know. You could have found the LG website too.
Your proposal about 24/96 is difficult to say. If they were WAV files I'd feel better about them being supported, but the play does support FLAC. However the fact that it supports FLAC does not necessarily mean that it supports 24/96 FLAC. You'll likely just have to try and see. Or look at the manual. Again, Google is your friend here. -
LG BP330 sound quiet on MKV files
By zunah in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th May 2013, 10:52 -
How do you create an SACD?
By hashslingingslasher in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2010, 16:59 -
SACD encoding
By dvdfreak1971 in forum AudioReplies: 6Last Post: 28th Nov 2010, 16:48 -
SACD to digital format
By shredcaster in forum AudioReplies: 13Last Post: 30th Aug 2010, 09:33 -
DTS custom DVD n a few other SACD ?uestions
By jackhandy566 in forum AudioReplies: 3Last Post: 8th Jan 2010, 05:51
