Ok here's another question instead..
When I use FFMpeg, I've been using the -r command/syntax thing to change the frame rate of the looped still image and the output video file. But when I made the fps 1 in an mp4 file, playing it in VLC is glitchy, in that when I full screen it, the video still stays the original size, and seems to be lagging?
So what frames per second settings are acceptable for different file types?
Look, what I think you are trying to do is admirable (giving YT a small but high quality upload), but you have to remember that EVERYTHING that you upload to it is going to be reencoded, and be encoded AS video+audio.
So, with the exception of the smallness of the upload, you really are NOT making anything any easier for yourself by using pic+audio. In fact, I am guessing that, depending on the softwares in use by YT, you could very well be making things HARDER by using pic+audio.
So I would suggest a high quality video+audio encode for upload: x.264 @ CRF 16-18 and 384kbps mp3. Then it will encode correctly by Youtube, and also play correctly in VLC, etc. Btw, use constant framerate for the video and constant bitrate for the audio.
Just my suggestion - take it or leave it.
Scott -
YouTube Upload Settings
By roflwaffle in forum Video Streaming DownloadingReplies: 5Last Post: 5th Feb 2012, 20:13 -
Cant upload video to youtube
By Florida in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2011, 01:33 -
Help convert Mp3 so i can upload it on youtube ^__^
By Jenniilovekpop in forum AudioReplies: 10Last Post: 30th Nov 2010, 18:06 -
Creating Youtube (mp4) from mp3 and image
By robertpnl in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2010, 10:11 -
Trying to join jpg converted to avi with mp3 and upload to youtube.
By Yosho in forum EditingReplies: 2Last Post: 24th Apr 2010, 21:02
