  1. Hi
    I'm having problems restreaming from one rtmp to another.
    ffmpeg -i "rtmp://IP/live/streamname.stream pageUrl=http://URL.com swfurl=http://www.website.com/player/player.swf live=1" -isync -vcodec copy -b:v 400k -acodec copy -b:a 128000 -ar 32000 -f flv "rtmp://IP/streamname"
    This is the command I have.
    Two things:
    1. ffmpeg has stopped working windows says and i have to close and reopen it.
    2. when it does work, after a random amount of time it will crash and say in the cmd window (I'm running inside a bat) an error in yellow text. something to do with DTS i cant remember the error but when it does it again ill post a screenshot. there is another error but this DTS one is the most common. I think its refering to the audio not sure.
    Please advise.
    EDIT - SCREENSHOT
    Thank you
    Can you play the stream okey?
    Have you tried google the sanity failed error?
    Try also search or post in http://ffmpeg.zeranoe.com/forum/
    You could also try stream with something like vlc.
  3. Hi
    The stream plays okay but when the error starts it stops the stream from playing and i gotta restart.
    I've tried googleing but there is nothing I understand.
    I've already posted in zeranoe forum for ffmpeg but there are no responses and the admin doesn't answer pm's or accept instant messenger invites.
    I cannot use VLC that's not an option.
    I'm really stuck.
