    Jul 2013
    SouthWestern Virginia
    I would like to be able to convert these recordings to mp3 to allow for portability. Anybody got an idea?
    Jul 2013
    Also, I do have DISHANYWHERE and can easily play the recordings on my computer. Is there a program that can RECORD while I play the music, then allow me to convert to mp3?
    DVR? Please give more detailed information.
    Aug 2006
    I have never tried it, but looking at the VideoHelp tools section maybe Total Recorder would work for capturing audio played on your computer. It is not free, but it is not expensive either, and you can try before buying.
  5. Run RCA audio cables from the DVR to the computer's audio inputs. Play the video on the DVR, record on the computer using whatever audio recording software you want (Audacity, Windows Sound Recorder, etc.).
  6. Texan V Bot's Avatar
    Feb 2006
    All Sound Recorder Vista? I think it might be free!
    It Started In Texas
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Not with the over abundance of information you posted!!!
