hi guys,
i just bought this camcorder from a friend for a roughly $500 and 10 months to paid, now i am looking for a decent and cheap Wide angle lens adapter..
Canon WD-58H 58mm 0.7x Wide Angle Converter Lens is so freaking expensive, ( i live in canada ) price is $200-$300 and that is so crazy price...
do you guys know any cheaper than this crazy canon lens?
i saw some in amazon like Vivitar brand and Zeikos,, but i need to ask you guys first..
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Any photo store or best buy will have cheapie WA converters hanging on a hook in bubble packs, sony makes some cheapies also.
Just be aware that you pay the big bucks to 1) minimize fisheye curvature distortion, 2) minimize chromatic aberration (rainbowing), particularly at the edges, and most importantly 3) maintain the ability to zoom-through while holding focus.
http://www.bhphotovideo.com/c/search?ntt=0.7&refineSearchString=0.7&sts=ma&Ns=p_PRICE_...angle+adapters -
hello sir thank you for quick response..
so i saw this cheap one http://www.bhphotovideo.com/c/product/256058-REG/Canon_8030A001_WD_58H_58mm_0_7x_Wide.html
and how come this one is more expensive?
http://www.bhphotovideo.com/c/product/618336-REG/Canon_3572B001_WD_H58_Wide_Converter_Lens.html
and are they both fit to my HF S20? sorry I'm beyond newbie,,,i just wanted that wide angle look -
Having not used either of those lenses I can't give you a specific answer except to say it probably has to do with the parameters I mentioned earlier. (It's not out of the question a better, cheaper manufacturing process was developed along the way -- I don't know.)
Any 58mm-threaded lens or filter should work on that camera.
edit: looks like the less expensive lens has three pieces of glass, the more expensive one has four. Both have excellent reviews going back to 2008 and 2009. (The more expensive lens seems to be newer.)Last edited by smrpix; 12th Jul 2013 at 07:08.
Canon Vixia HF S20 and Final Cut Pro 6
By amriteshvara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Sep 2011, 11:43 -
Shotgun Mic for Canon Vixia HF S20
By amriteshvara in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 18th Jul 2011, 14:37 -
Can I use a 30Mbps memory card on a Canon Vixia HF S20 camcorder?
By Willet Vary in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 19th Jan 2011, 00:59 -
Difference between Canon Vixia HF-20 vs Canon HF-S20?
By Wink in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Nov 2010, 16:46 -
Mini DV camera: should i use an HD-5050PRO wide angle or stay with DVR-5002
By stacks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2009, 14:50
