Page 3 of 5
FirstFirst 1 2 3 4 5 LastLast
Results 61 to 90 of 127
  1. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    i think it was flash player 10 but yes it has been fixed. that article is a couple years old.
  2. DECEASED
    Jun 2009
    Heaven
    Thanks for updating my KB, guys
    I seldom create FLV files, and also I never have used the "official" FLV tools.
  3. Flash player also supports mp4 for quite some time now,...
  4. DECEASED
    Jun 2009
    Heaven
    Come on, I am NOT that uninformed
    Or have you ever thought that a conservative guy like me can also be a WebM fanboy?
    No, never, jamais
  5. you ever thought that a conservative guy like me can also be a WebM fanboy
    don't really like webm atm. :
    a. it only supports VP8 and ogg vorbis (+ experimental VP9 and opus)
    b. no subtitles (at least I haven't seen any srt/ass -> WebVTT converter)
    c. aside from mkvtoolnix no real tool for 'editing'
    -> even more restricted than mp4, naturally far less powerful than mkv
    (wondering if vfr works fine with webm, when played back with flash player)
    but your good at hiding that fact
  6. According to unofficially sourced underground news, Multicoreware is giving-out SandyBridge, Hanswell, AMD Bulldozer PC and MS VS2010+SP1 for free to the interested volunteers who can invest their valuable time and efforts. I do not wanna take chances with current system setup capable of doing what I want - the way I want. Plus, I am not on MS-OS, I am way out. Somehow link for free give-away still not posted yet. Are you guys still interested to try free give-away and compile by yourselves.
  7. I would definitely seek support from you guys, I have pulled out old IBM-PC-AT, IBM Firtst Generation Serial Printer and a copy of Wordstar4 installed on it, left by my Grand-Grand-Pa as an antique to enhance or modify the standard SDHEVC - Super Duper HEVC that he could not finish due to lack of technology.
    When I opened his diary and read SDHEVC - Super Duper HEVC, his goal was to achieve compression ratio better than 90% with true 16k UUHD - Ultra Ultra High Definition with 24 bit true color depth. I am complete froze while calculating minimum system requirements even in nice summer evening, may be my Grand-Grand-Grand-Grand-Son will be able to calculate. I hope at least I can type or modify his standard on IBM-PC AT with worstar4.
    At least here I am, the first one to launch the concept of SDHEVC - Super Duper HEVC with compression ratio better than 90% with true 16k UUHD - Ultra Ultra High Definition with 24 bit true color depth.
    I will definitely need you guys. We will encode in such a way that none can decode.
    Am I missing something?
  8. DECEASED
    Jun 2009
    Heaven
    Definitely ---
    --- you still don't know when it is the right time for kidding and when it is the right time to be serious -.-
  9. Definitely ---
    Who told you that I am kidding?
    I am too serious for SDHEVC - Super Duper HEVC to full-fill my Grand-Grand-Paś dream.
    Are you serious to help me?
  10. @El Heggunte: happy, troll feeding.
  11. Member vhelp's Avatar
    Mar 2001
    New York
    i'm still messing around with this. tried a few other ideas just now but they did not work. no video, just audio is comming out. anway. trying one more thing now, encode should be done. but anyway, i wanted to ask, if anyone are able to preview or include a preview filter for the video as it encode ?
  12. DECEASED
    Jun 2009
    Heaven
    Not what you would like to read, and I don't know if this is helpful to you, but the first tab in the Properties window for the Monogram FLV Muxer has some fields which indicate the encode progress...
    Video stream:
    Audio stream:
    Duration:
    Avg. datarate:
    File size:
  13. Member vhelp's Avatar
    Mar 2001
    New York
    yes, i knew that, but its not "catch"able. i tried several different ways. the hdc is berried under another hard-to-read control. anyway. i was eluding to something similar. and, anyone can do this. so i thought i'd share it, being its not so obvious.
    ok, we all know and use mediainfo. well, fortunately for us, with this directshow hevc it allows the recording output data to be opened in shared mode. if you drag the i.e., video.flv file into mediainfo, you can see the duration as it encodes.
    thus, a person savy enough could rig something up to
    1. open the "source" video i.e., video.avs file
    2. utilize mediainfo to open/read for just the duration (or framenumber)
    3. take that info and plug it into another utility that only shows a preview of a given video i.e., video.avs
    4. using the info, show just the current or last frame processed.
    i was thinking of giving it a shot.
  14. DECEASED
    Jun 2009
    Heaven
    1) Man, you really should rename this thread to "How to Use Graphstudio" or something
    2) The graph below is what finally worked for me, therefore YMMV
  15. DECEASED
    Jun 2009
    Heaven
    3) This filter chain works with madVR too I have no idea of why it DOESN'T work with VMR7, VMR9 or EVR
  16. 3) This filter chain works with madVR too I have no idea of why it DOESN'T work with VMR7, VMR9 or EVR
    just for the notes, i couldnt make things work with evr or vmr's either ( using this infinite pin ), but i came up with this graph and it's working fine for me with evr or vmrs:
    which really is good enough for now if you ask me
  17. DECEASED
    Jun 2009
    Heaven
    @Jacobr: Many many THANKS for your useful post ,
    I wasn't aware that the Infinite Pin Tee filter was also known as Stupid Tee
  18. DECEASED
    Jun 2009
    Heaven
    @ vhelp: now that you know how to mux audio with an HEVC stream,
    what about updating the sample files in the first post
    Or now you think it wouldn't be worth the effort?
  19. Member vhelp's Avatar
    Mar 2001
    New York
    long story short...bc i (still) can't get them to work on my pc.
  20. DECEASED
    Jun 2009
    Heaven
    Originally Posted by Trepack View Post
    Well here is a video and information on how to insert a video. H265 in mp4 container with GPAC
    MPEG-HEVC Support in GPAC
    mp4 video play slow with virtualdub capture.I have renamed video.hm10 to video.h265
    http://youtu.be/1UhH3dQNGL0
    Happy testing
    Trepack, thanks for the clip Actually, until some minutes ago, I was messing around with an OUTDATED release of GPAC's MP4Box, and only after reading your post, I realized I was doing it all wrong (again)
    Anyway, now I have the most recent "nightly" MP4Box, and after remuxing a test video, I could play it in Graphstudio with the help from Strongene MPEG-4 Demultiplexor (mp4demux.dll)
    http://xhevc.com/en/downloads/downloadCenter.jsp
  21. DECEASED
    Jun 2009
    Heaven
    Yes, HEVC + MP3 in an MP4 container...
    (WARNING: the Strongene MP4 Splitter does not support AC3)
  22. Member
    Jul 2013
    Spain
    Final_Fantasy_XIV_A_Realm_Reborn_Trailer720[H265+AAC] MP4 container
    Final_Fantasy_XIV_A_Realm_Reborn_Trailer720[H265+AAC] (Mediafire)
    General
    Complete name                            : Final_Fantasy_XIV_A_Realm_Reborn_Trailer720[H265+AAC].mp4
    Format profile                           : Base Media
    Codec ID                                 : iso4
    File size                                : 20.0 MiB
    Duration                                 : 1mn 15s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 231 Kbps
    Encoded date                             : UTC 2013-08-04 13:03:42
    Tagged date                              : UTC 2013-08-04 13:03:42
    Video
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Format profile                           : Main@L9.3
    Codec ID                                 : hvc1
    Codec ID/Info                            : High Efficiency Video Coding
    Duration                                 : 1mn 15s
    Bit rate                                 : 2 036 Kbps
    Maximum bit rate                         : 7 656 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 fps
    Bits/(Pixel*Frame)                       : 0.074
    Stream size                              : 18.3 MiB (91%)
    Title                                    : h265:FMT=HEVC@GPAC0.5.1-DEV-rev4692
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 1mn 15s
    Bit rate mode                            : Variable
    Bit rate                                 : 192 Kbps
    Maximum bit rate                         : 202 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 44.1 KHz
    Stream size                              : 1.72 MiB (9%)
    Title                                    : aac@GPAC0.5.1-DEV-rev4692
    Hopefully someone takes a good encoder
  23. DECEASED
    Jun 2009
    Heaven
    Hopefully someone takes a good decoder
    Huh
  24. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    What player + decoder work at moment??
    Claudio
  25. DECEASED
    Jun 2009
    Heaven
    Claudio
    For the FLVs created with the Lentoid encoder: MPC-HC, PotPlayer, WMP ; splitter = the modified (HEVC-capable) FLVsplitter.ax ; Lentoid HEVC decoder ;
    For the AVIs and MKVs: MPC-HC, AV Splitter / LAV Splitter + Lentoid decoder ;
    For the MP4s : MPC-HC, Strongene MP4 Splitter + Lentoid decoder ;
    For the TSs: only the Osmo4 player so far, I suppose
  26. Member
    Jul 2013
    Spain
    Huh
    An encoder I meant sorry
  27. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    For the TSs: only the Osmo4 player so far, afaik
    Thank you my friend. Its works perfectly.
    the only downside, only work for me if change in Win7DSFilterTweaker, on MPC-HC player its fail.
    Claudio
  28. Member vhelp's Avatar
    Mar 2001
    New York
    still nothing works for me with audio, only video works. even muxing audio into video later doesn't work. i blame it on my very low system specs of mine.
    also, it seems there are very few testers out here, not very many users giving feedback on these h265 encoders. i must be due to the convoluting steps of prep work. a framerserver of some sort would remove that problem.
  29. DECEASED
    Jun 2009
    Heaven
    Perhaps Graphstudio can help you. Open one of those files in MPC-HC, pause, then goto GS ans press "Control + G", and tell us what you see
    For viewing the graphs used by WMP, first you'll have to register the DLL FilterGraphSpy.
    Well, we are testing pre-alpha software, and not many people want to feel like guinea pigs, I guess.
  30. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    For me audio+video is ok on my PC (I5+ Windows 7). I tested on my netbook (Celeron 1.2ghz) too. All works.
    Windows 8 + Klite Pack.
    Claudio
