I'm downsizing a lot of my bluray rips.
I've ripped everything losslessly with MakeMKV.
I want to shrink the size down but maintain the lossless audio.
On my rips with DTS-HD this is no problem. I simply select DTS-HD passthru in the audio tab.
However, on my rips that have only DolbyHD there is no option for this.
I tried the 'auto passthru' option in the audio tab but it does not work.
Can I do this with Handbrake?
Also on the audio... I have a few BD's without lossless audio.
I don't want any quality loss on any of my audio
For example Full Metal Jacket is Dolby AC3 5.1... should I select AC3 passthru for this... I'm assuming when the 'passthru' option is selected it does not alter the audio.
On a couple other notes....
1. Under the picture tab what is the modules option exactly... should I leave it on 2?
2. Without converting 20 movies to compare is it safe to assume that Constant Quality 18RF will be enough to not see any loss in quality....or is this overkill and is 20 enough?
3. I know variable framerate will lower the file size but should I keep constant to ensure quality?
4. Will there be any noticeable difference if I change the Optimise Video setting to any slower than medium?
Results 1 to 1 of 1
What happended to Dolby TrueHD
By ron spencer in forum Newbie / General discussionsReplies: 19Last Post: 27th Jun 2013, 09:11 -
Extract Dolby TrueHD Audio from MKV
By Spasch in forum AudioReplies: 5Last Post: 18th Feb 2013, 13:19 -
multiAVCHD with intermittent sound in Dolby TrueHD
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Jun 2012, 09:42 -
Where to find infos about Dolby TrueHD structure?
By Selur in forum AudioReplies: 7Last Post: 7th Jul 2011, 10:10 -
DVD-Audio to Dolby TrueHD or DTS-HD
By greymalkin in forum AudioReplies: 2Last Post: 20th Apr 2011, 11:01
