Hello
I have some MP4 files that I have downloaded and have renamed to suit my purposes. When I play the files through VLC media player the title displayed is completely different to the file name. I have no idea why this is happening. Can some please assist in helping me to get what displays in VLC to read the same as what the file title is?
Thank you.
you could try right clicking on the video file/properties/details and use the remove personal info button or if you can get to the name in properties click delete.
Hi all thanks for your replies. I went to MediaInfo program, opened the file in that program and found a heading titled "Movie Name:" and populated there was the unwanted title name. However as much as i can view that I cant find a way to remove that title and populate it with the same information as the file title.
Any ideas?
Thank you. -
its in the file header
you can try a 'hex editor' program, but they are a bit tricky youwill have blank the characters or replace with exactly the same number of charcters ( over write them )
avidemux might be the best way
just use copy video & copy audio and remux/save as new file with a new name
the new file should have 'your' new name in the header data
VLC 2.0.: metadata Artist, Title, Album, Genre, etc.
By HitTheRoad in forum MacReplies: 0Last Post: 14th May 2012, 15:10 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16
