Hi I have question. I have files recordered with sat receiver in hd in mpeg 2 transport stream format mpeg 4 avc bitrate ca 6 mb/s. I want to make blu ray discs from them with authoring works 5. What is the rule to set bitrate for blu ray disc. If I want not to lost quality and not make unnecesarily big files and be compatible with standalone blu ray. It should be the same as ts file or bigger ?
General
Complete name : G:\20130705 1350 - Polsat Sport HD.ts
Format : MPEG-TS
File size : 14.2 GiB
Duration : 5h 16mn
Overall bit rate : 6 435 Kbps
Video
Menu ID : 3101 (0xC1D) / 3102 (0xC1E)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=32
Codec ID : 27
Duration : 5h 16mn
Bit rate : 5 793 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.112
Stream size : 12.8 GiB (90%)
Encryption : Encrypted
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 5h 16mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -918ms
Stream size : 435 MiB (3%)
Language : Polish
Audio #2
Format : E-AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 6
Duration : 5h 16mn
Bit rate : 128 Kbps
Delay relative to video : -883ms
Stream size : 290 MiB (2%)
Language : Polish
Menu #1
Duration : 5h 16mn
List : 301 (0x12D) (AVC) / 311 (0x137) (MPEG Audio, Polish) / 312 (0x138) (E-AC-3, Polish)
Language : / Polish / Polish
Menu #2
Menu ID : 3102 (0xC1E)
Duration : 5h 16mn
Language : / Polish / Polish -
What settings of bitrate I should set for a blu ray disc from this file not to lose quality and not to make unncecesary big file ? The same as original source ? What free programme do You recommend for blu ray authoring. I like authoring works but it cost 100$
blu-ray multiple angles in a stream .... question
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 19th Sep 2011, 19:51 -
Encoding 46Mbps MPEG2 stream for Blu Ray?
By Killer3737 in forum Video ConversionReplies: 3Last Post: 20th May 2011, 16:49 -
How to rip and stream DVD and Blu-Ray?
By mskvarenina in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Nov 2009, 07:56 -
Author TS Stream to Blu Ray - Always need to be re-encoded?
By steve99999 in forum Authoring (Blu-ray)Replies: 12Last Post: 16th Aug 2009, 07:12
