I can not seem to set any higher compression ratio than 4854 kbps?
Why?
You're probably using "xvid home profile" . This places limitations on bitrate for compatibility with devices like Divx DVD players
Change it to "unrestricted" or another profile -
or is this related to something else since 4854 kbps looks more like a bit rate and not a compression ratio between a compressed and an uncompressed source,...
Yes, 4854 is the max bitrate for the "Xvid Home" (home theater) profile. Change to a higher profile (unlimited?) if you need a higher bitrate.
Xvid, Max B-frames for PS3 & Xbox 360
By duff916 in forum Blu-ray RippingReplies: 3Last Post: 15th Jan 2012, 20:13 -
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 02:48 -
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Change from PAL to NTSC DVD LG DR-4800
By mairel in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Jul 2009, 13:40 -
Region Code Unlock for LG DR 4800 ?
By carletto in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Jul 2009, 11:04
