Hello everybody,
I have a problem when I try to burn a SVCD with Roxio Videopack 5. I use MPEG 2 Files (encoded with TMPEG Encoder) and the standard SVCD (PAL) Template.
Everything is fine until I want to play the SVCD. After a few seconds the picture freezes (audio is still playing) for about 2 minutes. Then the picture goes on but the audio is (of course) out of sync.
This occurs alway at the same position. When I burn a SVCD with another burning program everything is working. But i need Videopack because of the Chapter handling.
Maybe you can help me.
Thanks and best regards
Schrulli
Hi,
thanks for your reply. What do you mean with internal compression. How does it work?
Thanks in advance
Schrulli -
if you look when you open video pack it has a button to do conversions... (kinda like tmpgenc) i've found that the file it makes don't look great on a comp monitor but they're good on a tv. and i've never had any sync prob while using it... I think if you find it you should'nt have a problem using it just tell it where your original file is...
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Roxio ?
By reygato in forum EditingReplies: 3Last Post: 20th Apr 2010, 07:50 -
Problems with Roxio MyDVD Basic v9 and other questions
By ForgetSun in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 02:29 -
Roxio Popcorn 3 - HELP?
By jphuber1959 in forum MacReplies: 8Last Post: 2nd Dec 2007, 13:50 -
Roxio vs Nero
By gthorley in forum Authoring (DVD)Replies: 25Last Post: 23rd Aug 2007, 02:08
