Hi,
my graphic card has DVI-I output port, I planned to link another monitor to it so I bought one Y splitter, But stupid me bought the
DVI-D to 2 x DVI-I and 2 x DVI-D to HDMI cables to connect to monitor.
Now, I tried connecting the monitors with these, and it worked initially, but as soon I logged off, the screen went blank and nothing displays and no error or 'NO INPUT SIGNAL' message.
Will this configuration of cables will work to interface the multiple HDMI monitors with DVI-I port or
do I need to buy an another Y spliter DVI-I to 2 x DVI-D?
It may help if you link to the splitter that you bought.
But if this splitter is not powered you have degraded your signal and that could be why your screen is now blank. Splitters should be 'active' ie powered.
Also, what is your graphics card. Only one dvi output ? -
Yes it only has one dvi-i and a vga output,
Now I have connected one monitor directly with dvi-i to usb cable and another one with vga, this setup is working, but with striking difference in display quality, the vga display look quite blurry compare to dvi display. It strains the eyes after a short while working on it.
What do you mean by active splitter? I think they are all the same?
Best Regards, -
If you fully read my reply you would understand what an active splitter is.
Here is one such device:
http://www.ebay.co.uk/itm/2-port-DVI-splitter-CMP-SPLTDVI10U-Konig-/271230155913?pt=UK...#ht_2479wt_986 -
And here is another way to do it.
1 x dvi to hdmi cable plus one of these:
http://www.ebay.co.uk/itm/HDMI-Splitter-2-Way-Switcher-Hub-1080p-TV-Amplifier-Full-HD-...ht_3008wt_1180 -
I have set resolution of 1920x1080p on both monitors.
@DB83 Many thanks, now I know what I need to fix it.
Thanks All, -
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Dvi to hdmi
By sanosuke in forum DVB / IPTVReplies: 9Last Post: 3rd Apr 2010, 06:57 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Aug 2009, 00:14
