When I try to play DivX Movies on my computer most movement becomes pink then it resets to the normal color and starts over again. I thought it was just the player but I tried a bunch of different ones and no go. It also affects it when I try to encode my divx's and they also have the pink!
What do I do?
Thanks in advance!
Do you have the Angel Potion codec? If you do, that's most likely what's causing the problem.
Actually I do. I thought it would be the best one because it includes smr and navi. Ok I'm going to try another one. Any sugesstions?
-NiX -
The Alpha 3.11 is the older one. The Kristal 4.3.3 might be a better choice.
You're right about the AngelPotion thing. -
nix: always check the FAQ before you post... http://www.vcdhelp.com/faq.htm#angelpotion
Philips DVDR3505/37recorder plays divx vod ?
By xbill in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 22:59 -
mpg plays badly in divx dvd player
By ssalim in forum Video ConversionReplies: 25Last Post: 3rd Apr 2009, 11:39 -
Philips DVP5992 plays AVIs, Divx too large
By strommsarnac in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Dec 2008, 23:32 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 18:25 -
Any software player plays Divx with subtiltle
By newnews in forum Software PlayingReplies: 9Last Post: 1st Aug 2007, 10:38
