    Jun 2013
    Chicago
    How I remove hard subs from this video? Is there anyway?
    General
    Complete name : C:\Users\ChoeyXD\Desktop\[Taka]_Naruto_Shippuuden_089_[720p][B90C5DC8].mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 286 MiB
    Duration : 23mn 5s
    Overall bit rate : 1 734 Kbps
    Encoded date : UTC 2008-12-20 23:17:12
    Tagged date : UTC 2008-12-20 23:17:12
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Duration : 23mn 5s
    Source duration : 1mn 36s
    Bit rate : 1 572 Kbps
    Maximum bit rate : 14.5 Mbps
    Width : 848 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 24.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.161
    Stream size : 260 MiB (91%)
    Source stream size : 260 MiB (91%)
    Writing library : x264 core 65 r1057M 5f8a149
    Encoding settings : cabac=1 / ref=8 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=0.6:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1572 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
    Encoded date : UTC 2008-12-20 22:20:23
    Tagged date : UTC 2008-12-20 23:17:25
    mdhd_Duration : 1385126
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 6B
    Duration : 23mn 5s
    Bit rate mode : Constant
    Bit rate : 160 Kbps
    Maximum bit rate : 165 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 26.4 MiB (9%)
    Title : Dolby Pro Logic II HQ
    Writing library : LAME3.98r
    Encoding settings : -m j -V 4 -q 2 -lowpass 17.5 -b 160
    Language : Japanese
    Encoded date : UTC 2008-12-20 23:17:24
    Oct 2005
    666th portal
    no. once they are encoded into the video they are permanent.
  3. no. once they are encoded into the video they are permanent.
    Yep! Simply remove [Taka]_Naruto_Shippuuden_089_[720p][B90C5DC8].mp4 and look for another source.
  4. though they are permanent,,but nothing is impossible..
    Mar 2011
    Nova Scotia, Canada
    It may be technically possible but not simple and hardly worth doing.
    Hard subs are not an extra layer on top of the video. There's nothing underneath them.
  6. Banned
    Freedonia
    Lots of things actually are impossible. For example, you cannot go back in time. You are not physically capable of throwing a baseball at 500 mph (roughly 800 kph). You are not physically capable of running 100 meters in under 5 seconds. You cannot exceed the speed of light. You cannot reproduce through asexual budding. You cannot know all the digits of pi. It's not possible for you to change the gravitational constant of the universe. And so on.
    It is possible with an awful lot of work to replace the subtitles with transparent shapes of exactly the same size that try to mimic the background, but many find these to be more distracting than they original subtitles. And in my opinion many of the before/after photos for various filters that do this are not indicative of real world results but represent either unachievable outcomes (ie. the photos were tampered with to make the results look better than reality) or are of very unusual cases where the process worked exceptionally well but the odds are high that you'll never achieve those results.
    Lots of new members expect miracles like this or the old "Can I remove one specific voice or instrument from an audio recording where there are other voices/instruments I want to keep in the same channel?" question that also can't be done. In this case, if you were willing to spend a minimum of $100,000 if not maybe even a million or more and had access to the best digital studios that Hollywood uses, yes, you could pay someone to work frame by frame and painstakingly remove the subs and the best people could probably give you a final product where you'd never know that subs were there. But as an ordinary consumer, there's no good way to do this and certainly what can be done isn't fast, even if you're willing to live with results that may be disappointing.
