    Apr 2013
    Midgar
    Hello there
    I have many .asf files and I want to join them in one single .asf file or .avi file, without loss of quality.
    Any suggestions for softwares?
    Thanks a lot.
    Apr 2013
    Midgar
    Downloaded. How I can join the asf files?
  3. add the files to the list and push the join button
    they have to have the same characterstics (e.g. dimensions) , or you can't join them without quality loss or with this program
    Jun 2013
    Chicago
    Try mkvmerge add your first file then click on append and add your second then click on start muxing
    Nov 2002
    asfjoin. You'll need to place a copy of asfbin.exe in the asfjoin folder.
    https://www.videohelp.com/download/AsfJoinSetup.exe
    Apr 2013
    Midgar
    Done! Thanks to all of you
    Apr 2013
    Midgar
    note: there's a little ''pause'' of something like half-second in the join point of the .asf files. there's a way to avoid this?
    I used asfbin
