I am in the process of switching to filming with an AVCHD Canon XA10. I am finding that the export times in premiere pro 5.5 are much, much longer than I imagined they would be. Could somebody give me some ideas for reducing export time?
I tried exporting a 3:40 long clip with these H.264 settings:
NTSC 1920x1080 29.97 fps deinterlaced
VBR 1 pass target 9.00 max 15.00
PAR widescreen 16:9, profile: main, level 4.2, render at max depth selected, use maximum render quality selected.
the estimated file size was 241mb, and it woudl take over 40 minutes !! I need to export about 90 minutes of video every day, so this won't work well.
I moved to the "HDTV 720p 29.97 high quality" H.264 preset, and it dropped it to about 30 minutes, but still incredibly long.
This is for youtube...as long as I can have 720p enabled (I don't really have to have 1080p), and it looks good, I don't need "top settings," but I desperately need to reduce the export time.
Any suggestions I could try?
shoot 1080p to begin with then there's no de-interlacing or artifacts. please fill out your computer specs in your forum profile. it would help to know you're not trying to do this on a laptop.
If it were me, I would:
A) Export out via FrameServer (Debumode Frameserver) directly into an x264 encoder GUI like MeGui or Virtualdub.
B) Export lossless compressed AVI > x264 encoder like MeGui, Simple x264 encoder, VidCoder, or Virtualdub.
Either would be quicker and yield better results in my opinion...........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
CS 5.5.2 fails to export HDV footage to tape/perplexed
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 19th Apr 2012, 22:41 -
Adobe Premiere Pro: I used DV footage and Photoshop stills - how to export?
By neckneck in forum EditingReplies: 12Last Post: 20th Dec 2009, 16:29 -
AVCHD Footage to SD (AVI for Premiere)
By foochuck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 86Last Post: 12th Nov 2009, 14:39 -
AVCHD footage to Movie
By provehighman in forum Video ConversionReplies: 5Last Post: 25th Jun 2009, 11:55 -
How to download AVCHD footage to Sony Camcorder
By Sparehead01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Apr 2009, 18:04
