I'm working with some game footage from my HD-PVR, I usually record in M2TS format, but I accidently made a few in MP4. I installed quicktime so the files would import into Vegas, the video seems fine. But about 47 minutes into the audio it seems to start playing audio from the beginning of the video..
If I play the MP4 in MPC or VLC it's totally fine, all the audio is there so something in Vegas is going wrong here and I'm really not sure how to fix it, perhaps there's a way to take the audio from the MP4 and reencode it into a better format for vegas?
I'm on Windows XP SP3 using Sony Vegas Pro 10c.
first try MP4Cam2avi , it might load your video and you can remux it to avi and change audio to PCM at the same time, then not sure if just Vegas alone will read those, mine is using ffdshow to read it
standard method is using intermediate file - but not sure how familiar you are with VirtualDub, Avisynth, and plugins like ffmegsource or DGindex for Avisynth, the goal is load it into Avisynth with those plugins , then load Avisynth script into VirtualDub and export some lossless out using lossless codecs like UT video, huffyuv, lagarith (you need to install some) together with uncompressed audio. Vegas will read those. You do not have to use lossless exporting uncompressed video but volumes of those videos are quite insane after exporting them from VirtualDub -
I finally found someone else having this problem. OP, did you try the fix suggested and did it work?
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
MP4 Formats on Sony Vegas will not Perform the Audio Correctly
By ♥Kat♥ in forum Software PlayingReplies: 9Last Post: 29th Dec 2010, 19:34 -
Sony Vegas MP4 problem
By Abas-Avara in forum EditingReplies: 27Last Post: 14th Feb 2010, 12:19 -
Sony Vegas 9 Audio Problem
By fdegrano in forum EditingReplies: 4Last Post: 24th Jan 2010, 20:13 -
Problem editing HD mp4 file with sony vegas
By excelsion in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2009, 23:08
