If i crop the left and right side of my video by 4, should I add borders and then resize. or should I just resize to 720 by 540 square pixels right after the crop. Does it make a difference?
Sure it does, it will add distortion to the image, if it's too much distortion to bother you are not is your decision
So it would be best to add the borders and then resize to 720 by 540 square pixels correct? In order to avoid disortion?
Are you referring to cropping and resizing a 4:3 DVD to 720x540 square pixels? If so it's not necessarily a simple answer as there's more than one way to resize a DVD. Either way I'd probably not add borders to replace the cropped video, I'd probably crop a little from the height as well to stop the picture from being distorted when it's resized that way.
Without knowing exactly what you're doing, have a play with this resize calculator (it's an exe but it's perfectly safe): http://www.mediafire.com/download/09v9bldu9a6hm00/YodaResizeCalculator.exe
Select the appropriate video input type/dimensions, add your cropping, adjust the resizing etc and the calculator will calculate the aspect ratio distortion for you. The idea being to then adjust the cropping and/or resizing as necessary to keep it at a minimum.
When you select a DVD as the input video, the calculator gives you the option of using ITU-R BT-601 coefficients. As you'll see when you check or uncheck that option, it changes the way a DVD is resized a little, which effects the way you'd crop and resize it. Without getting into a DVD resizing discussion, my rule of thumb is this:
If a DVD requires a lot of cropping each side (around 12 or more pixels) it's likely to use ITU resizing. If it requires very little cropping it probably doesn't. A 4:3 DVD is fairly likely to use ITU resizing. Most 16:9 DVDs don't (unless they're pretty old). -
Thanks hello_hello! I cropped 4 off the left and right side of my video and successfully resized correctly to 720 by 544 square pixels. 720 by 540 was the incorrect way to resize.
If you're resizing a 4:3 DVD without using ITU then you could also crop 4 pixels from the height and resize to 720x 540. That'd distort the picture slightly less and also give you an exact 4:3 output aspect ratio, but which way you do it is really personal preference. When resizing I aim for an exact 4:3 or 16:9 output aspect ratio if I'm already close after cropping, but each to their own.....
FitCD 4:3 and 16:9 crop/resize
By sambat in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2012, 14:35 -
Crop and resize bluray
By AMDgutten in forum Video ConversionReplies: 7Last Post: 22nd Aug 2012, 21:21 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 19:06 -
Video Crop and resize
By quxote in forum EditingReplies: 4Last Post: 27th Feb 2009, 11:48 -
Crop, then resize to 240x320?
By miamicanes in forum EditingReplies: 2Last Post: 29th Dec 2008, 23:56
