Unfortunately I set on AVCHD camera to record audio in PCM instead of AC3. Last clips imported to NLE (Avid Pinnacle Studio 1.1.0.) are without audio, in VLC player are OK. Playback on TV set (from SD card) is without audio. I found FFMBC as a proper tool and tried some controls, it is amazing.
Please can you help me to find failure "Unable to find a suitable output format" in my following FFMBC batch ?
Code:ffmbc -i test.mts -vcodec copy -acodec ac3 -ab 256k -strict output.mts pause
Seems to be AVCHD is the reason that NLE and Panasonic TV set require different audio codec as PCM.
Already I have edited hundreds of MTS without any difficulties. (Except of Adobe CS6 which is not importing any audio) ....
Wau we discovered side effect. Some month ago were huge discussions why imported MTS files are missing audio only on Premiere CS6, but not 5.5 This was my reason to siwtch to Pinnacle Studio.
Now I checked and really MTS with PCM audio is CS6 importing correctly - including audio
Thanks for advice demuxing helps, but I have to watch on timeline not to loss a lip-sync.
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 14:24 -
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 14:46 -
AC3 (5.1 audio files) and PCM 96/24bit stereo audio files
By joannes in forum Authoring (DVD)Replies: 2Last Post: 9th Mar 2010, 15:48 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 12:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 04:34
