  1. 1. Need help getting the Octoshape stream info for the below...
    http://www.yupptv.com/ndtv_good_times_live.html
    2. Is there a way to play this without the octoshape client installed.. Any help is appreciated.
    Thanks !
    Oct 2005
    666th portal
    no you can't even get to the stream player without installing the plugin.
  3. So can we get the stream url.. want to play using vlc if possible.
    Oct 2005
    666th portal
    probably if YOU install the plugin. doesn't mean you'll be able to download the video file though. it may be a protected stream.
  5. I tried to get the stream info after installing the Octoshape plugin but failed.. can anyone help ?
