This radio station mp3 audio stream is 256kb/sec:
http://stream0.wuftfm.org:8000/wufthd2256
However, when using 2 different softwares, Streamripper32 and the newer Stationripper, each on the top of the hour, when there are a few advertisements, the hour's worth of capture gets automatically deleted (overwritten). I like these softwares because they use very little cpu, (about 3%), even less than the Windows Task Manager uses.
My question is: is there a simple free low cpu usage software that can rip the 256kb/sec stream and not lose the accumulated capture on the hour? I tried StreamHijacker and it seems to work, but uses about 8 times more cpu power (about 24% instead of 3%). I am also concerned that StreamHijacker might be doing some kind of unwanted audio processing (based on the much higher cpu usage).
I've used TotalRecorder quite a bit. Bought it ump-teen years ago for $12.
Non-answerI've used TotalRecorder quite a bit.
Reason:
1) Total Recorder is not free
2) Total Recorder is not a ripper, it is a sound card recorder
Fortunately I found the answer.
Castripper:
http://download.cnet.com/CastRipper/3000-2168_4-10482064.html
or
http://www.fileden.com/files/2006/11/30/441298/CastRipper.rar
Rips the 256kb/sec stream, does not overwrite (delete) the stream at the top of the hour, and uses less than 3% cpu.
Problem solved.
Question how to capture this audio stream and turn into mp3
By jimdagys in forum AudioReplies: 22Last Post: 7th Nov 2013, 13:46 -
Capture audio from web stream ?
By Zetti in forum Capturing and VCRReplies: 2Last Post: 12th Dec 2011, 18:20 -
Question how to capture live audio stream of KJAZZ
By jimdagys in forum Video Streaming DownloadingReplies: 7Last Post: 13th Nov 2010, 20:26 -
Question how to capture PBS Frontline stream
By jimdagys in forum Video Streaming DownloadingReplies: 3Last Post: 10th Nov 2010, 22:48 -
Question about number of listeners to a particular audio stream
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 21:57
