Results 61 to 90 of 114
I haven't looked at jagabo's but I think it's because AVI v1.0 vs. AVI v2.0 / OpenDML . The former might have problems >2.0 GB or sometimes > 4.0GB in some programs. You can open it up in vdub and direct stream copy it into an AVI 2.0 container
Or jagabo mentioned lagarith - if MEP accepts lagarith (you would need lagarith installed), that' s another option for smaller filesize.
Test this lagarith sample file -
FWIW I've uploaded the manual here:
https://dl.dropboxusercontent.com/u/4019461/MEP2013%20Manual.pdf
Terry, East Grinstead, UK -
It was only 2 frames , to see if lagarith was compatible with MEP (lagarith is a common lossless intermediate used in windows programs) - if it's not compatible, there is no use uploading the complete file
I'll upload a fixed timing clock in lagarith in case anyone else wants to use it for their own project, but looking at your youtube video, you probably want more time increments in the animation represented, not fewer . Maybe even a realtime clock with seconds
Just my opinion - but this is a simple plain clock. It might be suitable for something like a cartoon sketch. I would use a clock face that matches the content more appropriately -
Except for the '2 hours every 60 minutes' error that jagabo spotted. I think that's true of all the clocks, alpha and non-alpha, that have been discussed so far, based on the original I found at
http://www.motionbackgroundsforfree.com/technology-free-backgrounds/free-technology-ba...-passing-time/
The only correctly synced clock I found was the recorded, yellowish one I showed in post #15. I'll probably search for more, (although free ones of good quality seem hard to find) because I've now finally worked out how to use what I've previously called the 'alpha sandwich' technique, but which PDR has told me is properly called 'luna matte'. That extends my choice over animated and recorded clock videos. And with much lower file sizes (unless converted with Lagarith). The downside is that I need to use chroma key on my clock, an extra step avoided with the alpha channel types, but that's not really a big deal in practice.
It seems MEP users are rare here. But for any that does end up in this thread with a similar question about using transparency in MEP, here's a summary of how I did it:
Thanks for all the help, especially from PDR and jagabo; it's been a terrific learning exercise.
Yes, even the latest one I uploaded is messed up too
Here is a loopable fixed timing-sync one (for sure this time
) , with tick marks and a black outline frame.
Now how about that Andy Murray guy
Thanks, runs sweetly in sync and looks good in white with the border. But 'canvas' doesn't seem high enough?
Oh, and would it be possible to shorten the minute hand a bit, so that it doesn't significantly overlap the numerals?
Er, also (you did say I should be very specific about what I wanted!), would a 25 fps version be possible please, which is my usual my project standard? Presumably your 30 fps is why the minute hand doesn't consistently advance one minute per frame.
My nerves wouldn't take the strain after a while. Had to repeatedly take a break and come here upstairs and play with my clocks.Now how about that Andy Murray guy
Terry, East Grinstead, UKLast edited by terrypin; 8th Jul 2013 at 13:49.
The embedded alpha is not working in your screenshot (it shouldn't be "white" around the clock)
Are you sure these 2 videos worked ok "automatically"
https://forum.videohelp.com/threads/357196-How-to-add-transparency-to-a-video-clip?p=22...=1#post2252633
The only difference is this last one was saved with AVI2.0, and lagarith compression
Or did this one work ok ?
https://forum.videohelp.com/threads/357196-How-to-add-transparency-to-a-video-clip?p=22...=1#post2252802
" fixed_lagarith_AVI2.0.avi.7z" was the same, except premultiplied alpha, (just the timing was messed up) -
This is what it should look like , notice it's "transparent" around the clock, not black
There is a thin black border
Your screenshot shows the image without the embedded alpha (it's disregarding the alpha)
Or was it AVI 2.0 MEP has a problem with ? Did you need AVI 1.0 ( you mentioned something about vdub "old format AVI" ) ? -
If it helps to explain, I've attached the "luma matte" or MEP calls it the "alpha keying object" . Just extend it the length of the video. When you do the "sandwich" technique, you should see the same thing as the screenshot in post 73 . A thin rim of border is remaining due to the diameter of the "white" circle
So you can see, if you made the "alpha keying object" larger diameter or smaller, you would get less or more black border revealed
All these things are really the same thing, but with an embedded alpha, you don't do anything like keying or "sandwich", just drop it on the timeline. With the "sandwich" method, you're just separating the alpha out onto a separate track.
But the initial disussion was how to do it with embedded alpha, sort of whole point that started this discussion. So we still need to clarify what works directly in MEP, without keying, etc... just drop on the timeline. There seems to be some conflicting information in your posts -
No problem, I'll make a 25 fps version , one we clarify what formats are supported (alpha channel directly, where you can just drop the video on the timeline)
In fact, it's easy to do in most editors - you just "interpret the fps" (since every frame already has a "tick" movemnt represented in this current version) . In effect, it's just slowed down by 25/30 (same number of frames)
The reason why it's 720 frames: 12 hours * 60 min/hour = 720 increments in minutes . So each frame represents a minute increment (one tick) . It doesn't matter if it's 25FPS or 30FPS or whatever. This is what "interpreting" in a NLE does. The same number of frames are there (nothing added or dropped), just played back faster or slower according to the FPS you enter (and thus the duration is either shorter or longer)
But I made the same "goof" probably as the other examples you downloaded from other sites, in that it's 12 hours represented for a complete revolution of the "small" hand, not 24 hours - DUH...
"conforming" in a NLE is different. Frames are added or dropped to "conform" to the timeline settings that you have. In contrast to "interpreting", the duration is the same. So if you drop 30.0 FPS footage onto a 25.0 FPS timeline by conforming to the 25.0 FPS timeline, frames are dropped (usually every 6th frame) , which of course results in jerky motion
If you did the opposite - drop 25 FPS footage onto a 30.0 FPS timeline, extra frames would be added to make up to 30.0 FPS. Most NLE's have either a duplicate or blend mode, so eitehr duplicate frames or blended frames are added to make up to the 30.0 FPS timeframe when "conforming"Last edited by poisondeathray; 8th Jul 2013 at 15:00.
ok but that was uncompressed
did lagarith work for any of the tests (by "work" I mean did the alpha work properly in MEP) ?
Did the alpha channel video in post #66 work properly in MEP ?
https://forum.videohelp.com/threads/357196-How-to-add-transparency-to-a-video-clip?p=22...=1#post2253018
And if you save "old format AVI" did it "fix" the alpha channel so it could work properly in MEP ?
I'm assuming you want a compressed 30-40MB file (when unzipped) , not a 2-3 GB file -
Thanks both. Husband duties interrupt play early tonight so I'll get back on the case tomorrow.
I confirm my focus is now exclusively on the alpha channel approach - no mask, no keying in MEP. But I'm pleased that I've mastered the alpha sandwich method, as that means I can roll my own!
Monday 8 July 2013, 20:50 UK time.
Jeez, I'm still stuck doing menial labor. But if I don't do it my fun budget will get severely reduced.
By the time I get to make my clock, I'll be out of time, hehehe.
One thing's for sure, anybody plugging MEP in the future will get laughed outta here.Last edited by budwzr; 8th Jul 2013 at 19:33.
Terry, here's some clock parts if you can use them.
And here's an actual working clock
http://files.videohelp.com/u/135518/ClockAnimation.aviLast edited by budwzr; 9th Jul 2013 at 01:33.
Should look like this:
You like it? Or no? It's different, right? You can't find that on YT or Google, hahaha. -
Hope that my detailed summary answers these so I won't try to duplicate here.
Well, all things being equal I'd prefer to work with smaller files. But operation is important too. As you saw from my typical usage example in post #52, for the current application I intend to extract just a fragment of the 12 hours so I would like that to run smoothly. Post#41-jagabo-simple_clock_premultiplied.avi was 2.6 GB but it loaded quickly into MEP. Like all so far though its 30 fps makes it slightly flawed for my 25 fps projects. Other ideal improvements were covered in post #71.I'm assuming you want a compressed 30-40MB file (when unzipped) , not a 2-3 GB file
I've spent most of today methodically re-testing all files and preparing a summary which I hope will correct any earlier confusion.
Note that I've renamed all (unpacked) filenames to show original post # and author. I've preserved the rest except where further detail was needed to describe it more fully.
Post #: 7
Filename: Post#7-jagabo-clock10s.avi
FPS: 97 fps into MEP set to 25 fps.
Imports OK into MEP?: Yes
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/jagabo-post%237-clock10s.avi.jpg
Size looks OK?: Yes
Hr/Min ratio OK?: Presumably (too short to test)
Result example: Not worth showing.
Any other comments: Watermarked test clip. Commercial alpha channel transparency.
Post #: 37
Filename: Post#37-PDR-simple_clock_premultiplied.mov
FPS: 30 fps into MEP set to 25 fps.
Imports OK into MEP?: No
Size looks OK?: Yes
Hr/Min ratio OK?: Yes
Result example:
Any other comments: No message on trying to import. I use MOV regularly and Quicktime is installed. I naively converted it with SUPER 2008 to AVI but as PDR advised later that lost the alpha channel. So the result I showed in post #39 was after further work with that AVI. Note that AVI is 25 fps, not 30. Sorry if my enthusiastic opening ("Bingo - thank you, I have it working!") was misleading. It was working - but not with alpha channel.
Post #: 41
Filename: Post#41-jagabo-simple_clock_premultiplied.avi
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2341-jagabo-simple_clock_premultiplied.avi.jpg
Size looks OK?: Yes
Hr/Min ratio OK?: No (2 hrs every 60 mins).
Result example: https://dl.dropboxusercontent.com/u/4019461/Post%2341-jagabo-simple_clock_premultiplied-AVI.mp4
Any other comments: Best so far. Despite size, MEP loads it quickly. Possible enhancements? 1. Correct timing; 2. Slightly smaller minute hands that don't hide the numerals; 3. Narrow black border
Post #: 41
Filename: Post#41-jagabo-simple_clock_premultiplied.gif
FPS: ?
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2341-jagabo-simple_clock_premultiplied.gif.jpg
Size looks OK?: Yes
Hr/Min ratio OK?: Cannot test
Result example: Static
Any other comments:
Post #: 42
Filename: Post#42-PDR-2frames-uncompressed_premult.avi
FPS: 25 fps into MEP set to 25 fps.
Imports OK into MEP?: Unsure, see below.
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2342-PDR-2frames-uncompressed_premult.avi.jpg
Size looks OK?: Yes
Hr/Min ratio OK?: Too short to test.
Any other comments: Apparently imports and plays (in a flash) but I'm puzzled why it occupies LESS than 2 frames on the timeline.
Post #: 42
Filename: Post#42-PDR-2frames-uncompressed_straight.avi
Screenshot(s) in MEP: Identical to the Premult above.
Size looks OK?: Yes
Post #: 48
Filename: Post#48-PDR-uncompressed_premultiplied.avi
Screenshot(s) in MEP: Cannot test
Size looks OK?: Cannot test
Result example:
Any other comments: Crashes MEP. No message, but hour glass runs indefinitely and status bar reports 'Initialising Audio Decoder (please wait)'. Forcibly close MEP.
Post #: 62
Filename: Post#62-PDR-2frames-lagarith_test_AVI2.0.avi
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2362-PDR-2frames-lagarith_test_AVI2.0.avi.jpg
Size looks OK?: Yes
Any other comments: Same puzzle about length on MEP timeline as for Post #42 files.
Post #: 66
Filename: Post#66-PDR-fixed_lagarith_AVI2.0.avi
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2366-PDR-fixed_lagarith_AVI2.0.avi.jpg
Size looks OK?: Yes (assuming there is no border beyond the white face).
Hr/Min ratio OK?: Yes, but see below.
Result example:
Any other comments:
Post #: 68
Filename: Post#68-Terry-PDR-Uncomp-Premult-BW-OldFormat.avi
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Terry-PDR-Uncomp-Premult-BW-OldFormat.avi.jpg
Size looks OK?: Yes
Result example:https://dl.dropboxusercontent.com/u/4019461/Post%2068-Terry-PDR-Uncomp-Premult-BW-OldFormat-avi.mp4
Any other comments: Presumably because of the frame rate conflict, after 25 frames the minute hand has moved from 12 to 6.
Post #: 70
Filename: Post#70-PDR-v2_lagarith_straight.avi
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2370-PDR-v2_lagarith_straight.avi.jpg
Size looks OK?: No
Result example: https://dl.dropboxusercontent.com/u/4019461/Post%2370-PDR-v2_lagarith_straight-avi.mp4
Any other comments: Top and bottom cut off. Presumably because of the frame rate conflict, after 25 frames the minute hand has moved from 12 to 6. And, of course, I was mistaken last night in reporting that it imported OK, when clearly the alpha channel has not been recognised.
Post #: 81
Filename: Post#81-budwzr-ClockAnimation.avi
FPS: 59.94
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2381-budwzr-ClockAnimation.avi.jpg
Size looks OK?: Yes
Result example:
Any other comments: No alpha channel. Only 1 hour. MEP struggles to preview it.
Post #: 87
Filename: Post#87-PDR-25fps_2frames_LAGS_AVI1.0.avi
FPS: 25
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2387-PDR-25fps_2frames_LAGS_AVI1.0.avi.jpg
Size looks OK?: Yes
Hr/Min ratio OK?: Can't tell.
Any other comments: Shorter minute hand looks good.
Post #: 87
Filename: Post#87-PDR-25fps_2frames_png.mov
FPS: 25
Size looks OK?: Yes
Result example:
Any other comments: Nothing appeared on timeline. No message. Yet played (albeit fleetingly) in VLC and IrfanVie. Wouldn't play in MPC-HC or WMP. QT Player gave 'Error -2048: Couldn't open the file QuickTimePlayer.exe because it is not a file that QuickTime understands,' but then proceeded to play it!
Post #: 87
Filename: Post#87-PDR-25fps_2frames_UT_AVI1.0.avi
FPS: 25
Screenshot(s) in MEP: Same as Post#87-PDR-25fps_2frames_LAGS_AVI1.0.avi
Size looks OK?: Yes
Any other comments:
Post #: 88
Filename: Post#88-PDR-25fps_uncompressed_premult.avi
FPS: 25
Size looks OK?:
Hr/Min ratio OK?:
Result example:
Any other comments: Crashes MEP. No message, but hour glass runs indefinitely and status bar reports 'Initialising Audio Decoder (please wait)'. Had to forcibly close MEP.
Post #: 97
Filename: Post#97-jagabo-25fps_uncompressed_premult_vdub.avi
FPS: 25
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2397-jagabo-25fps_uncompressed_premult_vdub.avi.jpg
Size looks OK?: Yes
Result example: https://dl.dropboxusercontent.com/u/4019461/Post%2397-jagabo-25fps_uncompressed_premult_vdub-avi.mp4
Any other comments: Whew, we got there! Excellent co-operative effort, thanks.
Post #: 97
Filename: Post#97-jagabo-25fps_uncompressed_premult_vdub_lag.avi
FPS: 25
Screenshot(s) in MEP: https://dl.dropboxusercontent.com/u/4019461/Post%2397-jagabo-25fps_uncompressed_premul...ub_lag.avi.jpg
Size looks OK?: Yes
Result example:
Any other comments: By the time of this test I had uninstalled that UT codec as part of my trouble-shooting the VirtualDub issue.
Terry, East Grinstead, UKLast edited by terrypin; 10th Jul 2013 at 05:28.
It looks like none of the lagarith tests worked with alpha channel.
UT is UT Video Codec, you need that installed for the "25fps_2frames_UT_AVI1.0.avi" test
https://www.videohelp.com/tools/Ut-Video-Codec-Suite
I shortened the arrows, and change to 25FPS.
So the question now is what compressed format works properly in terms of alpha channel support in MEP . Note: These are just 2 frames each to test compression -
Here is the full uncompressed file (in 7zip), it should be the same format as the one jagabo used that worked (multipart openDML) - so worse case scenario if none of the other compression formats work - you can use a 2.5GB file
Hahaha, Terry, that was a genuine heads up, not a slight. I do a lot of compositing, and I see you moving in that direction.
Each software brand has a different methodology and nomenclature, but Vegas is the most straightforward and intuitive, and is widely used by independent filmmakers and wedding videographers.
P.S. Vegas doesn't make DVD's. -
AVIsynth -- how do I add an audio wav to a video only clip.. [SOLVED]
By vhelp in forum EditingReplies: 7Last Post: 19th Nov 2013, 06:27 -
Avisynth add blank audio to a clip??
By duhmez in forum Video ConversionReplies: 1Last Post: 13th Dec 2012, 04:58 -
How to convert .mov (with alpha video 32bits) into .flv with transparency ?
By akinnzip in forum Video ConversionReplies: 1Last Post: 8th Jun 2011, 10:41 -
any free tools to resize/clip mpg2 and add black borders?
By extent in forum EditingReplies: 4Last Post: 16th Dec 2009, 18:23 -
Ulead Video Studio 11 - how to add multiple sub and more movie clip
By mic2x in forum SubtitleReplies: 0Last Post: 27th Aug 2008, 13:52
