-[Error] [7/4/2013 8:35:54 PM] Exception message: Object reference not set to an instance of an object.
-[NoImage] at MeGUI.MediaInfoFile.CorrectSourceInformation(MediaInfo& oInfo, String strFile, LogItem infoLog, Int32 iPGCNumber)
-[NoImage] at MeGUI.MediaInfoFile.GetSourceInformation(String file, LogItem oLog, Int32 iPGCNumber)
-[Error] [7/4/2013 8:35:54 PM] Stacktrace
-[Error] [7/4/2013 8:35:54 PM] Inner exception: null
--[Error] [7/4/2013 8:35:54 PM] MediaInfo - Unhandled Error
-[Error] Unhandled error
does that .avs preview ok in vdub ? post any error messages if any
what about another simple avs ? does it preview ok in vdub, also check megui
If the .avs are ok in vdub, then it's a megui bug . Try redownloading, and/or reinstalling (if your using the installed version) , or trying another older or newer version of megui , or ditch megui for something elseCode:version()
Yes the .avs works fine in virtualdub and can be previewed in media player classic. I'll try re-installing MeGUI thank-you!
How can i Use VDub Script[.vcf] into Avisynth Script[.avs] ( Megui )
By Maskoff in forum EditingReplies: 1Last Post: 25th Jun 2013, 15:30 -
avs script giving me fits
By willmoodom in forum Newbie / General discussionsReplies: 32Last Post: 30th Sep 2009, 03:43 -
How do I create an AVS script
By Sopt Finder in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 13:17 -
AVS script and Subtitle Workshop
By sambat in forum SubtitleReplies: 3Last Post: 19th Apr 2009, 10:20 -
This correct avs script for this source?
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 01:24
