I have some DVD's that have NO Video_TS folder on them. They play in DVD players but when I open them on my computer there is nothing inside. What program can I get to rip the video off in a format the FCP will like?
OK, then take a print screen and show us the contents of the disc, according to the File Manager.
Which version of Windows are you running? Maybe the discs use a newer version of the file system than Windows is able to read? Are they normal DVD video discs or could they be data discs which happen to contain other types of video files such as AVI? Are they burned or pressed discs etc? If you open one of the discs with a program such as ImgBurn what info does it provide?
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
How to rip DVD's: Image File or VIDEO_TS-Folder
By flashandpan007 in forum DVD RippingReplies: 3Last Post: 9th Feb 2010, 10:08 -
rip dvd folder and keep both audio channels ???
By hulinning in forum DVD RippingReplies: 12Last Post: 16th Feb 2009, 11:43
