I'm switching over to Deblock QED as DGDecodeNV doesn't have the CPU=6 parameter which does full strength deblocking. But I'm not sure what setting in Deblock QED will have the same effect? Ideally I would like it to only deblock the areas that need deblocking and to completely eliminate the blocks.
Or should I use the Deblock or Deblock QED function in McTemporalDenioise? I usually do the script below but from what I remember in this thread it was said that there was some sort of problem regarding my crops which meant I couldn't use the DeBlock function of McTemporalDenoise?
Code:McTemporalDenoise(settings="medium", interlaced=true) # Sharpening strength is 150 AssumeTFF() # or AssumeBFF() depending on the source QTGMC(Preset="Super Fast") SeparateFields() SelectEvery(4,0,3) Weave()
				Results 1 to 17 of 17
	You don't want the same effect. CPU=6 deblocks everything, whether it needs it or not. Deblock_QED deblocks only the blocky stuff. You don't want the same effect anyway as all deblocking softens the picture and often CPU=6 is like using an elephant gun on a flea. You want to deblock only as much as is necessary. I begin with the default settings which are often enough, and take it from there.
 From the Deblock_QED page:
 http://avisynth.nl/index.php/Deblock_QEDDesigned to provide 8x8 deblocking sensitive to the amount of blocking in the source, compared to other deblockers which apply a uniform deblocking across every frame.
	deblock qed (like most deblockers) is for a progressive source
 for an interlaced source (Didée's code):
 par=getparity()
 SeparateFields().PointResize(width,height)
 Deblock_QED(24,28,uv=3)
 AssumeFrameBased()
 SeparateFields()
 Merge(SelectEven(),SelectOdd())
 par ? AssumeTFF() : AssumeBFF()
 Weave()*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	Or could I just do it like this (my video is interlaced)?
 Code:AssumeTFF() QTGMC(Preset="Super Fast") Deblock_QED(24,28,uv=3) SeparateFields() SelectEvery(4,0,3) Weave() Last edited by VideoFanatic; 3rd Jul 2013 at 19:15.
	The corrected script would likely run without errors. Whether or not it gives the results you want is a different matter, you just have to run some vido thru it and see. In these case you don't need all those values in "24,28,uv=3". Those are the defaults anyway. Just typing DeBlock_QED() means the same thing.
 Just waiting to see how long it takes for those missing periods to get you into trouble again.  Last edited by sanlyn; 25th Mar 2014 at 08:17.
	I'm trying to use DGDecNV instead of DGIndex because DGIndex has a bug in it where when an encoding in a queue starts - at random it can encode at a slower FPS than what it should. DGDecNV encodes at about 1FPS slower but at least it's stable in that it doesn't have that bug. Unfortunately it doesn't support CPU=6 so I'm trying to find a good deblocker.
 Here's a script I normally use:
 I was under the impression from this post to add the following before McTemporalDenoise however it's causing problems as though I encoded a TFF video as BFF.Code:McTemporalDenoise(settings="medium", interlaced=true) # Sharpening strength is 150 AssumeTFF() QTGMC(Preset="Super Fast") SeparateFields() SelectEvery(4,0,3) Weave()
 Code:SeparateFields() .PointResize(width,height) Deblock_qed() .AssumeFrameBased() SeparateFields() .SelectEvery(4,0,3) .Weave()
 How can I get this working?
 What is the code needed for full strength deblocking and will this still do no deblocking on parts of the video that doesn't need it?
	Why not use BlindPP that is part of DGDecode? All the same control you are used to, but you can still use your hardware decoder.
 http://rationalqm.us/dgmpgdec/DGDecodeManual.html#BlindPP
	I'm confused. DGDecodeNV does not have BlindPP, I can't see that function in the user manual.
	BlindPP is part of dgdecode.dll
 You do not have to decode with DGDecode to use BlindPP. It is a standalone filter. If you read the DGDecode documentation you will find that BlindPP can be used with any video source.
 In your case, you will decode with DGDecodeNV and then call the BlindPP filter which is contained in dgdecode.dll.
	OK thanks. It's working. I have a 1080i source I'm converting to 720p with Avisynth. Normally the video comes out fine however when I add this as the last line I get dots all over the picture:
 BlindPP(quant=2, cpu=6, ipp=false, moderate_h=20, moderate_v=40)
 How can I get it working correctly?
 Also when I try to add the default settings as folllows: BlindPP(quant=2, cpu=6, ipp=true, moderate_h=20, moderate_v=40) to the top of the script (when the video is still 1080i) I see this error message: Need mod 16 height.
	I'd also like to suggest that CPU=6 is probably overkill. I usually use CPU=2 and I almost never go over 4.
 5 and 6 bring in deringing filters that can over soften things your picture.
 VideoFanatic, can you descripe the 'dots' (size, color, etc.)?
 Oh, and you probably should deblock BEFORE you resize or deinterlace. Give manono's script a go.
  Media Player that can deblock & dehiss?By VideoFanatic in forum Software PlayingReplies: 6Last Post: 20th Jun 2013, 20:21
  How do I use DeBlock with or without McTemporalDenoise?By VideoFanatic in forum RestorationReplies: 43Last Post: 14th Oct 2012, 14:12
  x264 deblock -3-3By miss in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2010, 06:58
  Need ideas on the best way to do this...Fade, smooth and deblock video.By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 02:34
  Help. Avisynth Error Message "no function named deblock"By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 28th Sep 2008, 00:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
