    Jun 2013
    South Africa
    Ok My previous Thread about Vegas 12 Hanging up blew over... now I have another problem and this time with Adobe Media Encoder...
    My Log Error:
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Untitled.prpr oj
    - Output File: C:\Users\Thurstan Naidoo\Documents\Adobe\Premiere Pro\4.0\Sequence 01.m4v
    - Preset Used: Custom
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:35:33
    7/3/2013 3:00:28 PM : Encoding Failed
    Could not read from the source. Please check if it has moved or been deleted.
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Untitled_1.pr proj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:36:34
    7/3/2013 3:01:29 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS.prproj
    - Output File: C:\Users\Thurstan Naidoo\Documents\Adobe\Premiere Pro\4.0\New.m4v
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:37:21
    7/3/2013 3:02:17 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_1.prproj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:37:48
    7/3/2013 3:02:43 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_2.prproj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:39:38
    7/3/2013 3:04:33 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_3.prproj
    - Output File: C:\Users\Thurstan Naidoo\Videos\Sequence 01.m4v
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:43:28
    7/3/2013 3:08:23 PM : Encoding Failed
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 02:58:09
    7/3/2013 3:23:04 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_4.prproj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 03:00:20
    7/3/2013 3:25:15 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_000000.jpeg.prproj
    - Output File: C:\Users\Thurstan Naidoo\Videos\Ragini MMS_000000.m4v
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 03:01:29
    7/3/2013 3:26:24 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\Ragini MMS_5.prproj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 03:33:51
    7/3/2013 3:58:46 PM : Encoding Failed
    - Source File: C:\Users\THURST~1\AppData\Local\Temp\ghj.prproj
    - Video:
    - Audio:
    - Bitrate:
    - Encoding Time: 03:46:04
    7/3/2013 4:10:59 PM : Encoding Failed
    Jan 2007
    Republic of Texas
    In your previous thread, I think Aedipuss was on to something in Post #6.
    https://forum.videohelp.com/threads/357092-Vegas-Pro-12-hanging-up-on-encodes?p=2251227...=1#post2251227
    You have a crappy source file. First, export to an intermediate using a lossless codec, like Lagarith .avi. (Yes, it will create a HUGE file, but you can delete it after the second stage.) Then, encode the lossless .avi to whatever final format you want.
    Jun 2013
    South Africa
    Thanks for the reply but I just found a solution to the problem so Adobe has a solution to the problem where the dynamiclink folder was missing the Premiere shortcut which supposed to be present in that folder, and now everything is working great!!! if to make it any easier that someone requires the solution I'll be happy to quote on here for convenience
    Jun 2013
    South Africa
    and also it seems Boris Continuum Complete doesn't get along with Sony Vegas, because Vegas responds well without it, to my really crazy understanding:
    1. BCC rapes Vegas
    2. Vegas gets Aids
    3. Vegas dies an early death
  5. What version of each software are you using? You may have 32-bit 64-bit incompatabilities.
    Jun 2013
    South Africa
    Boris for Vegas is both 32-bit and 64-bit.. I have both installed and I am using Vegas 12 Pro 64-bit.. but it seems as I said they do not get along, so right now Adobe premiere is doing the job for me.
    Jun 2013
    South Africa
    but I am open to any suggestions to help me out, if you need extra info like my specs, please look at my profile
