  1. I download this codec pack from the link in the tools section but it won't even open when I try to install it. Downloaded twice - same result. Anybody have this problem are know where I can get a good set of codecs?
    PIV-2.4G ASUS MB, 1G Mem, WinXP
    are you using a download manager?
  3. No. I just do a normal download then double click, and get an error. Downloaded twice with no luck. I may not need this but thought I would try it. I could never get Slide Show Movie Maker to make a good avi, but I gave up after trying for two days anyway. I hope nothing wrong with my Windows 98se! I'll just get the Ulead product.
