Hello one and all,
I have a short video with sound. It is a *.r m file.
I want to burn this *.r m file onto a blu-ray BD-R. What program/software does this?
I have Nero 9.0 but it doesn't seem to burn Blu-rays .........only CDs and DVDs. I tried Imgburn but
it doesn't recognize a *.r m file.
Thanks for reading this.
andy
It's Wimbledon fortnight so to quote John McInroe "You can't be serious man !!"
real media is not a valid video format for blu-ray, only VC-1, H.264 or mpeg-2. you will have to re-encode.
ImgBurn will burn any type of file onto a blank blu ray disc as data, as long as it is small enough to fit the target disc. Use Build mode.
If you intend for this to be a blu ray video, then you're in a world of hurt. You'll need to convert to a format that is acceptable for blu ray video. I don't know if MultiAVCHD will accept .rm files as input or not, but it might be able to do the conversion for you, and output as blu ray video format. -
Take a look at:
https://www.videohelp.com/hd#tech
Therefore, you would have to convert your .RM file to Blu-Ray~compatible video and audio.
And considering most .RM files do not have great quality, I serious doubt they would be worth converting to Blu-Ray.
Yes, latest versions of Nero can record to Blu-Ray discs.
Converting RM to Blu-Ray video+audio is an entirely-different story though.
possible to put MP4 and MKV on Blu ray to play on PS3 without re-encoding?
By heckubiss in forum Authoring (Blu-ray)Replies: 1Last Post: 13th Jan 2013, 03:36 -
Can you put DVD quality (and structure) video on a Blu-Ray disc?
By rayden54 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2011, 02:17 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 16:49 -
Newbie ---- Need to learn how to put hi-def files to a blu-ray disc......
By JBIIRockets in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2009, 08:52 -
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 10:09
