Hey all, Hopefully somebody can help me here, Ive been trying for hours to figure this out but couldn't so decided to register here to hopefully get some help with this issue!
Basically ive converted a 1.85GB .avi home movie to a 5.38GB .mkv(3d.mkv.h264.ac3)file, Ive converted it to SBS 3D using DVDFab 9, Now in the original movie the sound is fine BUT after converting to SBS 3D using DVDFab 9 the audio becomes -4000ms out of sync.
Could somebody help and tell me what i might be doing wrong in the converting process or even some way of re-syncing my video please?
Thanks in advance.
Is it 4 seconds off all the way through, or is it in synch at the beginning and increases steadily (no big jump anywhere) to being 4 seconds off by the end?
If it's the same throughout, remove the delay using DelayCut. If it gets progressively worse it's maybe due to changing framerates. How long is the video and what is the framerate both before and after? -
Firstly thanks for your reply.
Ok the audio seems to be out from the very start, I'm at work at the min so don't have any details of the fps etc but I'll check when I get home.
Sent from my Galaxy Nexus using Tapatalk 2 -
Check carefully the beginning, middle, and end. If it's off by the same amount throughout, find out the delay precisely (ask if you don't know how), and remove it using DelayCut (ask if you don't know how). Then use the new audio when making your MKV, or replace the old one with the new one in the MKV (ask if you don't know how).
Audio out of sync when converting from MKV
By carlmart in forum Video ConversionReplies: 8Last Post: 22nd Dec 2012, 17:07 -
Mkv Audio sync problem converting to DVD
By yudopplyr in forum Video ConversionReplies: 14Last Post: 10th Dec 2011, 15:55 -
Problem with audio sync with an mp4/converting an mkv.
By Clowmet in forum Video ConversionReplies: 0Last Post: 21st Aug 2011, 09:58 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 16:03 -
Audio and Video out of sync when converting MKV's w/ GOTsent
By Peter25 in forum Newbie / General discussionsReplies: 3Last Post: 12th Apr 2009, 23:45
