Page 7 of 7
FirstFirst ... 5 6 7
Results 181 to 204 of 204
    Aug 2008
    Greece
    I remember what you answer that for now THERE ISN'T ANY WAY TO REMOVE CINAVIA PROTECTION.
    So this is still on.
  2. Cinavia only works when your player has cinavia detectors. If you dont use cinavia players, copy and convert cinavia discs into videos to play them on PC. Cinavia will not make sense. Feel free about it.
    Real media really matters. Just get BD DVD discs and say NO to online stream media.
  3. Banned
    Nov 2013
    San Diego, CA
    Sell your stuff somewhere else
    /Baldrick
  4. I remember a few years ago there was a video wrapper called Vodei codec,there was a solution found,it was called Vodei crap removal with instructions and with the use of a program called Graphedit thru a series of filters an bypass.Maybe somebody a lot more techsavvy than me can have a look at it and see if it can be use for cinavia.
  5. Banned
    Freedonia
    You're new, so you don't understand how Cinavia works or why that won't work. I'll explain briefly, although if you had read more in this thread and others on Cinavia, you would already know why.
    Cinavia is an audio watermark. It only exists on the audio files. We know only that it seems that it can't be heard by humans but the watermark exists in the portions of the audio inside average human hearing. So for example, if it was a watermark that only existed above 30,000 Hz (this is far beyond human hearing) it would be trivial to re-encode the audio with a filter on the higher frequencies and remove it. We know of no way to extract only the Cinavia parts from audio and it may not ever be possible to do so. We're not completely sure (as far as I know) that the Cinavia specifc parts of the audio can even be identified by people like us. If we can't identify it, we sure can't do anything to get rid of it. The amount of secrecy around exactly how it works and is detected is government level high, which to me suggests that very few people truly understand the inner workings and it's relatively easy to ensure that they don't talk. For example, if only 5 people know how it truly works and the word gets out, with 5 suspects it's pretty easy to narrow down who talked.
    The only technique that works is that if certain destructive audio filters are placed on a Cinavia infected audio file and the audio is re-encoded, the Cinavia specific portions of the audio are ruined so that they cannot be detected by Cinavia obeying hardware/software. They are NOT removed, they are rendered undetectable by ruining the audio. The audio cannot be completely repaired from this step and while it is possible to undo some of the damage from the Cinavia detection destroying work, it is NOT possible to completely undo it. Most people can easily tell that the audio is messed up. A few weirdos may not care, but most people will care and find this to be an unacceptable "solution".
  6. Member wulf109's Avatar
    Jul 2002
    In the old days of Quadrafonic 4-channel music they used multiplexing to put the rear channels in the 20-40mhz range. You then used a special decoder,SQ,QS,CD-4(RCA) or Derived 2 channel to decode the rear channels. Are you saying that cinavia uses a similar method?
  7. Go hunting through the Sony hack files that have been released for more clues ... especially the one called "spe_05" which has a folder name "AACS" might be a good place to look for a folder called "Cinavia".
  8. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
  9. Banned
    Feb 2013
    Hey Noahtuck
    That horse looks kinda dead to me, and he's still beating it to death.
  10. Originally Posted by gonca View Post
    Hey Noahtuck
    Maybe you're not familiar with the idiomatic phrase: http://en.wikipedia.org/wiki/Flogging_a_dead_horse
  11. Banned
    Feb 2013
    Hey Noahtuck
    Actually I am, that's why the wink.
    Just trying to make it obvious to hotblu
  12. Let me ask you all a different question.
    Have those of you that think I'm beating a dead horse actually looked inside of the files that have been released so far?
  13. Banned
    Feb 2013
    Dead horse
  14. DECEASED
    Jun 2009
    Heaven
    Well, I have just discovered that the "spe_05" thing is a 5GB multipart RAR file...
    therefore my answer is "thanks, but NO, thanks".
  15. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I suppose if one could get hold of the circuit diagram of the detector electronics then one could possibly find a viable solution? But then it may be possible to mod a player to remove that part of the circuitry?
  16. Member Cornucopia's Avatar
    @hotblu, I think you need to open one of those files and tell us what it does. Perhaps "deleteALL.exe" or "dban.exe"...
  17. Originally Posted by jman98 View Post
    Cinavia store code in phase changes in spectrum over 7kHz.
    code sequence (i assume relatively low speed - few tens bits per second perhaps or less) is spread with direct code spread spectrum method and it is used to modulate phase for audio signals in upper audio part. Modulation depth is relatively low depth (so ear can't perceive such modulation - we already knows that human ear is "insensitive" for phase changes around +-10 deg).
    With relatively low speed of changes this is not/shouldn't be perceived by human ear.
    Decoding is done by i assume self correlation (see sliding correlator approach).
    What can works with Cinavia is:
    Best method - detect Cinavia, apply phase changes with opposite sign i.e. restore original audio signal and efficiently remove Cinavia.
    Worse method - apply to signal a low pass filter up to the point where Cinavia no longer works, extrapolate by Spectral Band Replication algorithm removed part of spectrum.
    Perhaps applying SBR to original signal (mixing wet/dry) to point where SNR will be insufficient to reliable Cinavia detection (as any data transmission bellow some SNR Cinavia detection will fail - i assume spreading of Cinavia is sufficient to provide protection able to survive microphone recording i.e. i assume Cinavia is robust and perhaps SNR can be lower than 0 - nothing fancy in spread spectrum world).
    Perhaps correlation between channels may improve Cinavia detection - anyway if Open Source World will be able to create robust Cinavia detection algorithm then applying correction to nullify Cinavia will be piece of cake/easy pie.
    Btw.
    Going for http://en.wikipedia.org/wiki/Equal-loudness_contour i would say that best place to allocate Cinavia will be somewhere between 8 and 11kHz. Perhaps removing this part of spectrum can be sufficient (but designing such protection i would go for more robust coding and use also other parts of spectrum), area between 1 and 5kHz is very sensitive as human ear can perceive phase difference around +-1..2 deg.
  18. Originally Posted by Cornucopia View Post
    I don't need to, someone else already has and posted analysis of what's in them.
    https://forum.videohelp.com/threads/353091-How-to-remove-Cinavia-protection?p=2363814#post2363814
    ... let me know if any of you still think I'm flogging a dead horse.
  19. DECEASED
    Jun 2009
    Heaven
    Yes, it looks like the archive spe_05.RAR contains a folder named "Cinavia"...
    ... BUT we@Videohelp still don't know the actual contents of that folder --- and specially, whether that folder contains any useful info about how to remove the Cinavia watermark.
    Dec 2014
    San Jose, CA
    Cinavia is only an issue when watching an encode through a Blu-ray player.
    1) Plug your external device into your TV's USB port. This has always worked for me.
    2) If your computer is hooked through you TV like mine is, you can watch with - VLC or Media Player Classic Home Cinema But, in all honesty, I only use my computer when it's something I encoded (I encode all my stuff @ 24fps). Too many people these days encode @ 23.976 fps. Now this is fine if you're watching through a Blu-ray player or your TV. Both play everything @ 24fps to match the HZ level of your TV. However, computer players play @ the original frame rate. So when the frame rate doesn't match the HZ level, you get periodic choppy playback.
    Jul 2012
    Detroit
    Do not remove watermark from a stream. Simply, remove the watermark(s) from the audio file by remodulating it with an inverse of the stegano (stinko) key. This also pulls out the 'digital' embedments. I believe the number of keys are constant, otherwise the players would need frequent updates which doesn't appear to be happening.
  22. Member
    Mar 2006
    Great-why dont you share all of the keys and also some source code (C++ preferred) which will use said keys and do what you say leaving a cleaned audio file next to the source infected audio file which can then be remuxed back into the container for playback on any device.
  23. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    I have tons (literally) of "stinko" keys in my bathroom...which one will work best?
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  24. Member
    Jul 2012
    Detroit
    OK.
    Qz3FWD: Don't use C++. Sounds like a lot of work. I use available soft wares and custom built discrete board. Why don't you give me the C++ Libraries that emulate my discrete components and I'll see what I can do. Or you can do it. Need libraries to emulate chips such as op-amps, differential pll, frequency synthiesizer, monostable multivibrators, A/D converters, etc. Also, the libraries to access the pc sound board.
    How do I post / upload a sample video clip contained in a .MKV file?
    Will attachement to a message post handle a 280Mb file?
    It has two audio tracks, one with Stinkovia and the other wiped with Windex (no Stinkovia).
