Hello friends, sorry for my bad English and my inexperience.
It turns out that many times I've become mpeg4 video video (h 264) 25 fps to 23.98 fps with no problems, but I've had some exceptions, is that yesterday download an HDTV source video was encoded MPEG4 video (h 264) 25 fps, then I wanted to convert the video to 23.976 with Toolnix MKV, but the result I got was unexpected, the video remained in a duration inappropriate, and stay distorted video image, I remain sincerely video with exaggerated duration time, video I became properly to 23.976.
But because other videos I have been well??
What could it be??
Is there a parameter that I have that correct?
Help please I need to convert that video to 23,976 for audio sincronizarle extracted from an NTSC DVD.
Well here I leave the video information that has given me problems:
General
UniqueID/String : 214982128793168373074792376965711509120 (0xA1BC0D4B9E2EE7308AC2F55B0377B680)
CompleteName : D:\mov-world.net\Ein.tierisches.Trio.wieder.unterwegs.GER MAN.1995.HDTV.720p.x264-OldsMan\om-ein.tierisches.trio.720p\om-ein.tierisches.trio.720p.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 2.14 GiB
Duration/String : 1h 20mn
OverallBitRate/String : 3 793 Kbps
Encoded_Date : UTC 2011-06-19 15:29:55
Encoded_Application : mkvmerge v4.8.0 ('I Got The...') gebaut am May 24 2011 03:12:58
Encoded_Library/String : libebml v1.2.0 + libmatroska v1.1.0
Video
ID/String : 1
Format : AVC
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 5 frames
MuxingMode : Header stripping
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 3 408 Kbps
Width/String : 1 272 pixels
Height/String : 712 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 50.000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.075
StreamSize/String : 1.89 GiB (88%)
Encoded_Library/String : x264 core 115 r1995+537 0dc51e3
Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3408 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language/String : English
Default/String : Yes
Forced/String : No Please diganeme if I have to recode the video to convert it to 25fps to 23.98.
Thanks in advance, greetings.
Closed Thread
Please reread our rules about downloading warez/pirated video, https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
Buy it on blu-ray when it's released....or capture it from hdtv yourself.
Any decent way to convert higher fps movies to a lower 29.97 fps ? (or othe
By Jonz in forum Video ConversionReplies: 1Last Post: 5th Nov 2012, 03:01 -
Sync - Resample audio from video source of 29 FPS to 25 FPS
By Chastepe in forum AudioReplies: 6Last Post: 17th Oct 2012, 11:35 -
How to convert from 23.747 fps to 30 fps ?!
By SB4 in forum RestorationReplies: 7Last Post: 27th Aug 2012, 01:07 -
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23
