See below:
Hey all,
I know there are other programs which do this same job, there's a server-side one and also an Adobe AIR based one (which I didn't have success with), but for those of you that like to run an EXE file locally, you might find my tool useful next time you have to convert BDN / XML subtitles to DoStudio friendly ones.
Same usage as the others, this just rewrites the script in a Dostudio friendly way. It obviously won't work with Text Subtitles since Dostudio doesn't support those (and nobody seems to use them anyway), only Presentation Graphics.
http://netblender.ning.com/forum/topics/bdn-xml-dost-format-subtitle-converter-exe
Thanks.
devil (johner)
Results 1 to 1 of 1
Convert XML to SRT subtitle file
By subsync in forum SubtitleReplies: 7Last Post: 15th Jun 2015, 18:08 -
Converting subtitles to xml format
By DeNeDe in forum SubtitleReplies: 16Last Post: 22nd May 2013, 15:10 -
Srt subtitle converter
By fits79 in forum SubtitleReplies: 3Last Post: 12th Apr 2012, 05:38 -
DVDAuthor XML subtitle pre command syntax
By Advocas in forum Authoring (DVD)Replies: 0Last Post: 29th Mar 2009, 13:51 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 15:37
