Just over a year ago i bought the Hauppauge hdpvr, i have used this to archive sky+ recordings in hd, the issue that i have been having and researching for quite some time is that when i convert 50fps to 25fps the video goes choppy. Now i had a very long-winded way of converting to 25fps without losing motion but the end video was just moosh. My video is in h264 at 720p, with the audio at ac3 384 kbps, ideally i need a way to convert and edit this video (remove adverts) to a dvd complaint 576i 25fps file with a good picture quality and smooth motion, can anybody please help me with this? thanks
what do you use for video editing software? and it might help if you filled out your computer specs in your forum profile.
welcome to the forum
nero isn't very good. if you want something fairly easy to get the hang of sony has movie studio for a fairly reasonable price, and it goes on sale frequently at online shops. if you need something free you could try out lightworks, i think they still have a free version, and use eyeframe converter to get your source into a compatible format. something like shown here.
http://eyeframeconverter.wordpress.com/2013/06/06/249/--
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 12:06 -
Help with 720p video to 576i DVD (Only 25fps?)
By Killer3737 in forum Video ConversionReplies: 9Last Post: 16th Jul 2011, 12:34 -
AVer MediaCenter saves video at 50fps when there ment to be 25fps
By jamespoo in forum DVB / IPTVReplies: 1Last Post: 17th Jun 2011, 03:39 -
HDTV 720p 50 fps -> SDTV PAL 576i/p 25fps
By joosty in forum Video ConversionReplies: 22Last Post: 7th Nov 2010, 23:33 -
Converting a 720p .ts file from 50fps to 25 fps
By Bully9 in forum Video ConversionReplies: 14Last Post: 15th Sep 2009, 13:40
