Hello
Is it possible to use the DVD slideshow GUI in conjunction with - or as an integrated part of - Adobe Premiere Elements 11? If there are any tutorials or links on how to use them together, that would be great.
Thanks!
Steve
You could try the Avisynth Premiere plugin:
http://neuron2.net/www.math.berkeley.edu/benrg/avisynth-premiere.html
Dunno if it still works for new'er versions of Premiere?
If it does, then export as .avs(avisynth script) from DSG and import this way an uncompressed slideshow in Premiere. -
Hello tin2tin
Many thanks for your reply.
I have downloaded the plug-in and I'm just reading about how to install it.
I'll post back.
Thank you!
DVD Slideshow GUI
By spike47 in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 12:23 -
Help with DVD Slideshow GUI, please...
By MackoMaca in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2010, 11:31 -
DVD slideshow GUI
By andwan0 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 07:51 -
DVD Slideshow GUI help
By snafubaby in forum Newbie / General discussionsReplies: 11Last Post: 9th Sep 2010, 15:15 -
DVD slideshow GUI transitions
By dread in forum Authoring (DVD)Replies: 1Last Post: 14th Nov 2008, 13:05
