I have a Denon 2012DBP UD and I have copied all my original Blu ray movies in copies (with adding external srt Greek subs)...
For small size movies (max 25GB) I used JVC,Maxell,TDK,Sony and they work perfect!
For big size movies (up to 50GB) I used only Verbatim (Kagaku media) and all those discs during playback ht slowing of picture movement,lasting 1-2 secs.In a 2 hour movie I have seen this at least 10 times.It is very annoying.
It is easily observed especially when there is a person moving,or a car,or a boat...
Because in all other discs (25GB) it NEVER HAPPENED I concluded that Verbatim discs are not compatible for some reason with my player.
Also with all my original movies this problem never happened.
I have ordered Panasonic 50GB discs to try and unfortunatelly I don't have another BD player to see if these Verbatim discs work appropriate...
Does anyone else has Denon DBP 2012 to tell me his experience?
If anyone can help me I would trully appreciate it,thank you...
*In another similar post of me,I had mentioned that ONLY in Verbatim copied movies most times the whole picture freezed and the reproduction wasn't able to go on,but I searched and found that I was not using the minimum writing speed but I was using the variable.When I changed it to the 2X speed the problem never occured again...
I have used Verbatim 50 GB discs. My experience is limited because it's not possible for me to test on a lot of players, but yes, the 50 GB discs do have various playback problems on every BluRay player I have used. I think you will you have problems with the Panasonic discs and it's just the nature of the 50 GB discs to have problems. I believe that you will find that this problem is not a problem that only Verbatim has. It wouldn't surprise me if the Panasonic discs actually are worse.
Does anyone who faces freezing problems with 50GB BR discs during playback,found any solution?Most of my 50GB Verbatim (and Panasonic) freeze 10 minutes from the end of the movie!
Subtitles - progressive sync and incompatibility (srt and sup)
By sooojaded in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 14:59 -
An MP4 with some incompatibility issues
By danielbb in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jan 2010, 19:22 -
Denon DVD-1940CI multi hack please :)
By talla in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jul 2009, 12:32 -
Windows Media Video DRM incompatibility w/ NVidia cards using TV out?
By Bix in forum ComputerReplies: 10Last Post: 18th Sep 2008, 18:36 -
Denon DVM 1835 use in Brazil
By Brazil guy in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2008, 20:35
