i have done this hundreds of times with other svcd mpg's i download (all from the same source), but i have a few that are giving me problems when i am converting them to vcd using TMPGEnc.
what i have always done is open the MPEG Tools using the Simple Multiplex where i select "MPEG-1 Video CD" and browse for the svcd mpg,
then convert it. take that new mpg into nero which will burn the mpg into vcd format and allow me to play on my dvd player.
my problem is that with several of the mpg's i've tried converting recently, TMPGEnc just quits converting the file less than halfway through.
so instead of a 800mb file, it creates a 200mb file that i cannot do anything with except delete.
anyone heard of this? if so, what do i do?
i'm trying to refrain from re-downloading the original mpg's because it's a total pain in the ass.
help?
i'm still having this problem, and i can't figure out what the deal is.
this time, i'm using Daemon Tools because i have a bin/cue svcd, and i'm converting the mpg from the image using TMPGEnc to vcd, but it craps out 45% through.
please someone help -
Hi,
have you tried running a MPEG fix program across your files (like MPEGCorrector, VCDGear or TMPGEnc under Merge/Cut/Correct button). I suspect you have a MPEG file with errors which kill the encode. By the way I suggest VCDGear (latest version) as sometimes the file is really stuffed and it get truncated by the correction process. VCDGear will actually write the entire file, in segments.
TMPGEnc for HD to SD conversion?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 14th Oct 2011, 16:37 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
