  1. when i start smartripper,up at top says drive cant acess asapi ,can I change that somehow?
  2. do you have the aspi layer installed, in windows 200 and xp there is no aspi layer installed, if you do not ( and probally don't ) have the aspi layer, go to www.adaptec.com and get the aspi layer v4.7, it will install without the need for any adaptec product that needs to be present ( unlike the older version of aspi32.exe ) and best of all it free.
  3. Yes its installed,thats why idont understand when smart ripper fires up says cant acess asapi for this drive,I enabled dma.
  4. go to dup-dvd.com try forceaspi... it worked for me
  5. k, if not try dvd decrtptor
