I have a Vista computer with Happauge WinTV HVR 1600 tuner card. I have an old Sony CCD-TRV 308 camcorder with S Video in the front of the camcorder. This type of camcorder uses tape cartridges. I have no USB ports on this camcorder.
I would like to connect the camcorder to the computer via tuner card to capture the videos and save them on the computer.
1. What would be the best way to connect the camcorder to computer?
2. Quality is important when capturing the video. Will I lose the quality?
3. What software would I use to capture the video?
Thanks for your help.
S-Video cable from the camera to the Happauge WinTV HVR 1600 would be the easiest. I doubt you will get greatly improved video by capturing to uncompressed or lossless AVI from Hi8 tapes.
You probably have the ability to capture in high bitrate MPEG2 with the Hauppauge card but the result will be too high of a bitrate for DVD. You can save the high bitrate capture to an external HDD then transcode down to DVD bitrate to make DVDs for friends and family.
edit: you will also need an audio connection between the camera and the card since S-Video is "video only".
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 15:56 -
Capturing question.
By ingeborgdot in forum Capturing and VCRReplies: 13Last Post: 26th Jan 2011, 15:33 -
Capturing Question
By Jackf6 in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2011, 11:46 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 21:26 -
Capturing DV VHS deinterlace question
By bgmagic in forum Video ConversionReplies: 3Last Post: 13th Nov 2008, 08:57
