Search in the TOOLS section of this site and look for a bitrate calculator, the bitrate will also depend on how long your clips are (running time)
Given the framerates from your cameras, you should keep in NTSC, the result will play on any computer and many PAL DVD players, make a small test to see if it plays in one or two different ones.
If you still feel the need to convert from 30/29.97 to 25 fps, there are also guides around here, but I donīt know if itīd be worth it. You can also use AVStoDVD, a very good free software that will convert your movie clips (it can also convert the framerate) to DVD compliant files or even make the whole DVD with menus and all. -
You have to make it dvd compatible if you are making it a true dvd.
The audio for the first camera is not dvd compliant. It will have to be reencoded to 48khz. And the video is way too high for dvd.
Here are the specs for ntsc video:
Video:
Up to 9.8 Mbit/s* (9800 Kbit/s*) MPEG2 video
Up to 1.856 Mbit/s (1856 Kbit/s) MPEG1 video
720 x 480 pixels MPEG2 (Called Full-D1)
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps*
23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video)
16:9 Anamorphic (only supported by 720x480)
Audio:
48000 Hz
32 - 1536 Kbit/s
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
https://www.videohelp.com/dvd
That link contains what I just posted and includes the data for pal dvd.
You have to tell tmpgenc to use the ntsc or pal dvd preset. There are different bitrate levels of course. But you have to get it to dvd specs first regardless of anything else.
It might be better to use avstodvd as julitomg suggested. It will do the conversion and authoring for you. Tell it if you want a single layer or dual layer dvd and it will make it fit the disc. And you can do it with a menu too.
Edit - sorry for posting ntsc data - didnt' read you are in pal. But regardless dvd audio spec is 48khz for either format fyi.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
HD video camera hookup to digital projector
By MTguy in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2011, 19:08 -
Video camera that has digital zoom, is wireless and has an SDK?
By cautaro in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Jun 2010, 14:26 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 14:57 -
What to do with large AVI video files taken on my digital camera?
By scormodo in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2009, 11:13 -
Need advice on compressing video from digital camera
By lopardo in forum Video ConversionReplies: 3Last Post: 17th Jul 2008, 20:43
