My computer doesn't play Indeo 5(.11) files correct anymore. It seems like there are more dropped frames than captured ones. The files are ok, usually captured without any dropped frame. The only solution I found is to disable both scalability options.
To point this out one more time: I don't mean the scalability option for the compression driver, I mean the driver used by Player software to display the video files!
The bad thing is that the settings for the decompression filter aren't saved (tried with MS 6.4, MS 7 and Zoom Player), so I have to do that every time I play an Indeo 5 file. Is there a way to save these settings?
... and please excuse my bad english
