  1. when i convert avi to mpg , i get sync problems, the audio is off with the video by about 3 or 4 seconds any ideas? i've tried vitualdub, still no luck
    Mar 2002
    chicago
    how are you converting(CCE, TMPG)? you tried virtualdub...to do what exactly?
    try this:
    1) VDub: save wav
    2) avi-->.mpv (no audio)
    3) wav-->.mpa
    4) multiplex
  3. i used tmpg, what prog i need for step 3 on your list? i got the steps before that done
    Mar 2002
    chicago
    if you're using TMPG, change your audio source from the .avi to the .wav you extracted earlier--I personally would recommend an external audio encoder(I use toolame)--set that under environmental options/external tool(first option)
