I have two audio files
I am trying to merge the 2 tracks together, but when I have both of them in Audacity at once, practically every menu item is grayed out, sadly, including export. How do you combine audio files of different formats? Or do I have to convert it first?
- MP2 (.mp3)
- PCM (.wav)
I was unable to duplicate your problem. I opened an .mp3 file, imported a.wav file, and was able to export and combine channels. What version of Audacity are you using? (I'm using 1.3.13) And what are the steps you are taking?
Buy My Books -
Could be because MP2 is not the same as MP3 (though you are assuming it is). They are in the same family, and GOOD apps that support MP3 OUGHT to be able to support MP2 as well, but it doesn't mean they actually do. Couldn't tell you if Audacity falls under that category or not.
BTW, from a purely tech standpoint, LPCM does not necessarily equal WAV, either. One is a container, one is a stream type. It's just that both are commonly used together. Yes, that's nitpicky, but little nitpicky things like that are the things that can screw up apps to where you're going, "huh?!".
What's the harm in decoding/converting the compressed file first? A few minutes of extra time? A few hundred MB? In the time it took to ask this question and get an answer it could have been done.
Scott -
Nevermind, it works now for some reason. Not sure what I did before...
Combine subtitle tracks in MKV
By Hikaru-Shindo in forum SubtitleReplies: 0Last Post: 16th May 2012, 04:42 -
[SOLVED] Application to combine video + sound tracks?
By yetanotherlogin in forum Newbie / General discussionsReplies: 15Last Post: 22nd Apr 2012, 18:38 -
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 09:55 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
Cleaning Up MPEG-2 Audio via Audacity
By cyberboy in forum AudioReplies: 4Last Post: 25th Aug 2008, 03:26
