Tried running SetMTMode with QTGMC deinterlace on DV avi and it causes intermittent brief video and audio static. Without SetMTMode the processed file doesn't have issues. Tried various settings within the SetMTMode command, nothing seems to eliminate the problem.
Any ideas what could be causing this?
Thanks.
Closed Thread
a. a deinterlacer should not influence the audio at all,... (it's video filter)
b. works fine here using Avisynth 2.6a4 MT:
-> assuming you used SetMTMode correctly and your filters are up-to-date, I would recommend to:Code:SetMemoryMax(768) SetMTMode(3,0) # change MT mode LoadPlugin("G:\Hybrid\avisynthPlugins\LoadDll.dll") LoadDll("G:\Hybrid\avisynthPlugins\libfftw3f-3.dll") LoadDll("G:\Hybrid\avisynthPlugins\fftw3.dll") LoadCPlugin("G:\Hybrid\avisynthPlugins\yadif.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\ffms2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\VerticalCleanerSSE2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\TDeint.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\SSE2Tools.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\RepairSSE2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\RemoveGrainSSE2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi3.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\nnedi.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\mvtools2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\mt_masktools-26.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\FFT3DFilter.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\eedi3.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\EEDI2.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\DirectShowSource.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\dfttest.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\AddGrainC.dll") LoadPlugin("G:\Hybrid\avisynthPlugins\LSMASHSource.dll") Import("G:\Hybrid\avisynthPlugins\QTGMC-3.33.avsi") # loading source LWLibavVideoSource("H:\TestClips&Co\interlaced_mod2crop.mpg",cache=false,dr=true,repeat=true) # deinterlacing SetMTMode(2) # change MT mode AssumeTFF() QTGMC(Preset="Fast") SelectEven() #distributor() return last
1. check if the source if okay at the scenes where you get these statics
2. check the tools that run during you encoding ('live lock'? Virus scanner interfering?...)
3. check the general system stability (overclocked? heat problem? memory health? ...)
Other than that posting a sample and the avisynth script you used might help for others to try to reproduce the 'artefacts' you encounter. (Artefacts might not be caused by QTGMC, itself but might be due to another filter not working well with MT the way you use it,..)
Cu Selur
Ps.: the avisynth plugin collection (including avisynth) I use can be downloaded as a whole over at my side as 'Avisynth extension'.Last edited by Selur; 27th Jun 2013 at 01:56.
Why a new similar thread? COntinue in https://forum.videohelp.com/threads/356950-What-could-be-causing-QTGMC-deinterlaced-vid...65#post2250265
Using Avisynth MT with QTGMC
By agni451 in forum Video ConversionReplies: 11Last Post: 15th May 2014, 08:37 -
Using QTGMC in ffmpeg
By agni451 in forum Video ConversionReplies: 1Last Post: 10th Nov 2012, 11:16 -
QTGMC Help
By TuFFrabit in forum Newbie / General discussionsReplies: 16Last Post: 23rd Jun 2012, 07:53 -
Help me get started with QTGMC
By JackDanielZ in forum Video ConversionReplies: 20Last Post: 3rd Jun 2012, 10:04 -
AnimeIVTC 1.06.1 in Xvid4PSP, SetMTmode script error
By sagat93 in forum Video ConversionReplies: 2Last Post: 1st Jan 2010, 22:30
