  1. Hi all, new forum member here.
    I recently upgraded from my trusty standard def VX2100 to a HDR-FX7 (as I much prefer tape to solid state media but had to go HD as that is sadly the way of the world these days). Obviously I don't want to use the FX7 to capture my footage to my laptop & my old little JVC MiniDV camcorder that I used to use in my VX days is not up to the job. So, can anyone suggest a cheap HDV camcorder that I can use as a capture cam?
    Don't care about features & I want it as cheap as poss - just something I can use so I don't wear down the heads on the FX7.
    Thanks for any advice anyone can give.
    Oct 2005
    666th portal
    there are canon hv20s around that still work. check ebay.
  3. Cheers mate, was hoping to spend a fair bit less than the £300 ($500) or so people are charging for them but if that's the only option then I may well have to go for one.
    Thanks for getting back to me.
