Hi,
I'm going to do a live show soon with video-projection backdrop on stage. As the music is electronica, I hope to run the needed playback drums and arrangements using audio directly from the video itself, playback on Mac + high quality USB soundcard + VLC/Videolan player.
Could anyone give me some advice for which video-format is best to use for playback with best audio quality, without loosing quality in compression?
Is it .AVI? .MOV? My budget doesnt allow to hire professional advice/consultant at the time being..![]()
If your playback will be on a Mac, use Quicktime (*.MOV), period, I say. The only way VIDEO has anything to do with Audio Quality would be if you have a limited bitrate budget and wanted to maintain a specific V + A QoS.
If you want further help, would be better if you actually gave Model #s for each link in your playback chain (incl. software).
Scott -
What about ISO? Create a BD ISO and get the free download of Slysoft VCD to mount it, and VLC will play it.
LAV splitter ignores preferred audio track
By xepyonx in forum Software PlayingReplies: 0Last Post: 30th May 2013, 08:04 -
Preferred software for stretching audio?
By Cygnus111 in forum AudioReplies: 10Last Post: 23rd Feb 2013, 13:24 -
AVCHD editor Sofware with lossless video output,which can handle PSF format
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Feb 2012, 04:56 -
best video output format for youtube, iphone, android?
By videdit in forum Video ConversionReplies: 2Last Post: 25th Oct 2011, 11:34 -
"Any Video Converter" output format choices - can anyone explain?
By slipkid in forum Video ConversionReplies: 5Last Post: 14th Feb 2009, 18:09
