Hi,
I was wondering if anyone here knows how to enumerate the computer's currently installed DMO filters?
I would like to make a application that enumerates all of the currently installed DMO filters.
I know this is possible as GraphEdit and GraphStudio next do it.
The reason I need this is that I work in a company that receives a lot of different types proprietary (CCTV) video on a daily basis.
Many times the person sending me the video is not a very technical person, so I send him an app that exports all of the currently installed programs and DirectShow Filters (using "InstalledCodec"), and compare them to the ones our program uses to process that video on his computer, so that I can find the codecs and process the movie on my computer.
Now once in a while I receive a video which was processed using DMO filters, which unfortunately I found no way to enumerate them (yet).
Does anyone here have a clue on how to approach this?
Thanks ahead,
-Bumps
Why not simply tell/ask the person to:
- Start->Run..->dxdiag
- Save All Information
- Send the whole 'DxDiag.txt' thing or just the 'DirectShow Filters' section?
other than that, I would recommend to check out the SourceCode of Graphstudio from their SVN, it should include the code you are looking for.
Cu Selur -
Hmm I had no idea it also exports the installed codecs, thanks a bunch!
Its just a shame that it does not include the CLSID but it should work for the mean time.
I'll have a look at the GraphStudio source anyway, I just hoped I woulden't have to go in there.
Thanks again,
-Bumps -
If you just need the names of the filters that are used for a specific file http://www.laganiere.name/directshowTut/section1.shtml and GSpot should both be able to display these (not sure if either cvision or GSpot has an export function)
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00 -
Need some filters or something
By salatoimikud in forum Video ConversionReplies: 1Last Post: 28th Nov 2011, 14:33 -
why do we use deinterlacing filters?
By deadrats in forum Video ConversionReplies: 12Last Post: 26th Dec 2010, 17:58 -
Using filters while capturing
By lime- in forum DVB / IPTVReplies: 6Last Post: 27th May 2009, 19:00 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 12:32
