Results 1 to 20 of 20
    Aug 2008
    Greece
    Hi.
    Is there any database or site or forum we can find REAL RIPPED BLURAY SUBTITLES and not translated or by earing subtitles to a lot of movies?
    Into pgs format and a program that can convert pgs subtitles files into simple greek srt subtitles.
    I interesting only for Greek subtitles.
    A LOT OF THANKS.
    canada
    Rip the subs from your own blu-ray and use subtitle edit to convert and translate to greek.
    Aug 2008
    Greece
    Is there any site/forum e.t.c. that i can find already ripped bluray subtitles even at english.
    And is there any program that i can convert english subtitles to greek.
    Aug 2008
    Greece
    So doesn't anyone find any site/forum or whatever it is that has GENUINE pgs greek subtitles???
    canada
    Nope,there's no site for pgs subs,they are all srt which saves a lot of bandwith,just look for greek srt which can be changed to pgs.
    Aug 2008
    Greece
    You don't understand why i want pgs subtitles.
    Because the most of srt greek subtitles i find it loose a lot of parts of the movie or it doesn't translate very nice like the GENUINE bluray pgs subtitles so......
    canada
    And you don't understand that I'm just stating a fact,pgs subs are better to have but subtitle sites are not going to supply pgs subs when srt subs are around 140KB for an average movie and pgs subs are around 6-20 MB and multiply that by a few thousand.Saves a ton of bandwidth for them.
    Aug 2008
    Greece
    Is there any easier(More automatic) program than suprip that i can convert any pgs subtitle into simple srt subtitle?
    canada
    Aug 2008
    Greece
    This program is MORE MANUAL than suprip is.
    It ask me to write every sentence so....
  11. I'm a Super Moderator johns0's Avatar
    canada
    No it isn't,it can do tesseract.
    Aug 2008
    Greece
    YES IT IS.
    I try it.
  13. I'm a Super Moderator johns0's Avatar
    canada
    Import blu-ray sup,It will ask to use tesseract,click ok and begin ocr,if it comes to a word it does not recognize it will give you an option to add to dictionary if it is correct,if the word is misspelled then you can correct the word(s) and click on change all,it will continue translating the pgs to text till it gets to another word it doesn't recognize.
    If it keeps asking for word corrections all the time then your pgs is hard to ocr,when this happens i run the pgs through BDSup2Sub and choose to output as idx/sub where i change the resolution and color to something easier for subtitle edit to read.
  14. YES IT IS.
    I try it.
    As said: You should install Tesseract together with a greek dictionary in Subtitle Edit (SE). The dictionary can be installed from within SE. In case of an installer version of SE you put the Tesseract file here:
    %appdata%\subtitle edit\Tesseract\tessdata
    and for the portable version here:
    \Tesseract\tessdata
    Aug 2008
    Greece
    I have installed the greek dictionary and STILL do the same thing.
    IT DOESN'T convert automatically the sup into srt. It asked me every line to MANUALLY fix the line so....
  16. It's more importan that you get the Tesseract than the dictionary
    Aug 2008
    Greece
    One more time i download both of them and still the converting sup to srt it ISN'T automatic and i must entel EVERY SINGLE LINE so.....
  18. Now you really look like these so called "translators" that made you search solution at first place.
    There is no free lunch, you can get something without hard labor only in movies you watch.
    Aug 2008
    Greece
    Ok i don't completely automatic convert sup to srt but NOT ALL MANUALLY but a very little user adding characters of every word...
    Dec 2014
    Greece
    fits79 i understand you! (Ειμαι πατριωτης σου και) i have the same problem. The .srt translated subs are pathetic in some level. For me (I have built a private Cinema with an 128" screen and all HD sound and picture) is necessary to have the most perfect-fix greek subs for my films. So i want too, to download the pgs subs. So far i find in a few movies srt english subs from pgs original english, and i translate them ONE BY ONE for god sake in greek! Also, because i LOVE the 3D technology i put them in some scenes right or left if there are any important object in the center of the screen. Just like cinema subs. If you want any of my subs, i have for the : AVATAR Extended Cut 1920x1080p DTS-HD MA , GUARDIANS OF THE GALAXY IMAX EDITION 1920x1080p DTS-HD MA and STAR TREK INTO DARKNESS 1920x1080p DTS-HD MA. I can send them to you!
