First I have opened a video using megui and have created .avs file. Later i opened .avs file in Vdub and applied some filters in it and save processed file. (.vcf ) . Now I want to use some script from .vcf file into .avs file and want to encode movie using megui.
Is it possible? if possible, Please guide me..
I am pasting some script lines from .vcf file.
VirtualDub.video.filters.Clear();
VirtualDub.video.filters.Add("brightness/contrast");
VirtualDub.video.filters.instance[0].Config(7,19);
VirtualDub.video.filters.Add("HSV adjust");
VirtualDub.video.filters.instance[1].Config(432,68656,288);
VirtualDub.video.filters.Add("sharpen");
VirtualDub.video.filters.instance[2].Config(24);
VirtualDub.video.filters.Add("smoother");
VirtualDub.video.filters.instance[3].Config(250,1);
VirtualDub.video.filters.Add("warp sharp");
VirtualDub.video.filters.instance[4].Config(309, 2);
VirtualDub.video.filters.Add("interlace");
VirtualDub.video.filters.instance[5].Config(0, 0);
VirtualDub.video.filters.Add("levels");
VirtualDub.video.filters.instance[6].Config(0x0000,0xE626,0x00FFFE8F,0x0000,0xFFFF, 1);
VirtualDub.audio.filters.Clear();
You can use LoadVirtualdubPlugin() to use VirtualDub filters in AviSynth. You'll have to transfer the variables manually. And it won't work for internal VirtualDub filters. Those you have to somehow estimate using equivalent AviSynth filters.
MeGui: AVS script creator problem
By Fed03 in forum Newbie / General discussionsReplies: 5Last Post: 23rd May 2013, 11:02 -
Add QTGMC Deinterlacer to MeGUI's avisynth script creator drop down list?
By Simcut in forum Newbie / General discussionsReplies: 2Last Post: 30th Jul 2012, 16:58 -
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
avs script giving me fits
By willmoodom in forum Newbie / General discussionsReplies: 32Last Post: 30th Sep 2009, 03:43 -
How do I create an AVS script
By Sopt Finder in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 13:17
